Odd suspension problems and vibration...
Old Jan 18, 2006 | 11:42 AM
TSX.Fury's Avatar
send me a link to JDM??
Ok these problems might be unrelated but I'm not really sure.
First the suspension problems...I installed Buddy Club N+ spec damper coilovers about 2 months ago and haven't had any problems until about a week ago. About a week ago I noticed that when I started up from a stop I could hear what sounded like a rubbing sound coming from my back right wheel. I'm pretty low but not so low I should be rubbing on stock wheels while drive stright on flat ground. Once I get up above about 10 mph the sound goes away. At the same time my shock (again only from the back right) started to be really squeeky , mainly when getting to the bottom of an incline and taking a right (I know that sounds wierd but I do it when I'm leaving my apartment twice a day). I have no idea what this could be and would really appreciate some help. As a note, I am about .5-1 inches lower on the N+ spec then I was on the Tanabe's I had before these and I have not gotten an alignment yet. I haven't notice any uneven tire wear so I should be fine but just in case that matters...
On a most likely unrelated note, I'm getting a vibration at high speeds (above 70-75). I have stock wheels (well silver stars but obviously stock bore size) so I don't know what else to check when it comes to the vibration. Again, I would appreciate some assistance.
The only thing that makes me think they could be related is that the vibration seems to be coming from the back right as well but I can't really tell as well. Anyway, thanks in advance for the help!!
Old Jan 18, 2006 | 11:52 AM
marketman's Avatar
JBW
I hope you find out what the problem is - hopefully it is not a problem with the N+ Spec's - Installed mine a few weeks ago but everything is ok to this point
Old Jan 18, 2006 | 02:01 PM
CCColtsicehockey's Avatar
for the vibration I would check that all the lug nuts are completely tight.
Old Jan 18, 2006 | 02:08 PM
moda_way's Avatar
I agree. If that doesn't yield any results, get someone to balance them for you.
Old Jan 18, 2006 | 02:22 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Old Jan 18, 2006 | 07:19 PM
TSX.Fury's Avatar
Hmmm checked the lugs and centering of the rims a few times.... I'll check them again and if it doesnt help see if the new wheels and tires help For the price I paid it better
No advice on the squeeky shock? Would spraying stuff down there with WD-40 be a bad idea?
Old Jan 18, 2006 | 07:55 PM
LuvMyTSX's Avatar
I have no idea about the other stuff, but I just had my front wheels balanced because of vibrating/shaking at high speeds, and everything's fine now.
Old Jan 18, 2006 | 11:17 PM
well hurry up already if you have the new rims in your posession get pics posted on the site pronto. Else I am going to create a thread for you with a this thread is worthless without pics smiley.
Old Jan 19, 2006 | 12:10 AM
HoRRo's Avatar
iVTEC no koe
Good luck on getting pics of the rims, he still hasn't even posted proper pics of the window trim!!!
TSX.Fury -> https://acurazine.com/forums/showthread.php?t=27437
Old Jan 19, 2006 | 12:52 AM
Yeah I know. Well he is soon about to get his own thread in the Photography section requesting pictures of both
Old Jan 19, 2006 | 10:31 AM
TSX.Fury's Avatar
ALEXANDRIA, VA, US 01/19/2006 4:00 A.M. OUT FOR DELIVERY
Will post pics asap
Oh oh and of the window trim too... I really promise this time.
Old Jan 19, 2006 | 10:41 AM
TSX.Fury's Avatar
Oh and the Eagle F1's to wrap them are coming on monday
Old Jan 19, 2006 | 11:18 AM
Will post pics asap
you are going to be required to put two of these on and take some pictures. however no using them in the winter.
Old Jan 19, 2006 | 11:19 AM
you should be happy with those
Old Jan 19, 2006 | 01:30 PM
pyoj's Avatar
if you still get the buzzing/vibrating noise, it might be the wheel bearings. I had my right passenger wheel bearing assembly replaced and that fixed the problem...
it might be worthwhile to have the dealer check it out. they replaced mine under warranty.
Old Jan 19, 2006 | 01:56 PM
TSX.Fury's Avatar
cool, hopefully it will go away after the alignment. I probably wouldn't be able to get a dealer to do that for me considering I've got quite a few mods into the car
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
MrHeeltoe
79
Oct 14, 2015 08:47 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
whitesoxsfan12
Sep 13, 2015 02:09 PM
