Navigation Version 4.56 Mod
Old Jul 5, 2007 | 01:22 PM
liquidg3n3rati0n's Avatar
Jon (PWP FTW)
hey guys i tried following all the steps on how to change the splash screen. i still am not able to change the splash screen. i have a 2007 tsx with the version 4.56 dvd. if anyone out there changed theirs please let me know how you did it with clear instructions. thanks i'd appreciate it
Old Jul 5, 2007 | 01:35 PM
msmching's Avatar
Ex-King of Pasadena
uhh.. i did mine. But mine's a 06 tsx. Is that a same version?! not sure if its the same version tho.
Old Jul 5, 2007 | 01:39 PM
Jon (PWP FTW)
could you check for me? it says the dvd version on the actual dvd in your trunk. if im correct i believe that the 2006 tsx's have version 4.55A?
Old Jul 5, 2007 | 04:17 PM
drigo's Avatar
2006 has version 4.31C
Old Jul 5, 2007 | 06:00 PM
clee109's Avatar
I Quit
^^^ Exactly, you may not be able to change the splash screen on your version following the 06 steps. Also, you need to do the 8 - 16 bit change described on the 06 instructions to make the image the right storage size etc.... So if it can work make sure the image is bitmap, 16 bit, the right pixel size, 216 bit color, etc....
Old Jul 5, 2007 | 08:48 PM
1slicktL's Avatar
yes and make sure to follow the direction and the size of the picture has to be exact after you convert it because the stupid navi is very picky
Old Jul 15, 2007 | 01:58 PM
Wisc Badger's Avatar
B A N N E D
the early 07's (such as mine) have ver 4.55a
i can't get mine to work either but it might be due to computer error or me just being stupid.
i cant get the bysin program to open on my computer in using the steps from that 06.
let me know if this gets figured out
Old Jul 16, 2007 | 01:35 PM
raheel616's Avatar
so the 06 can still upgrade there dvds?
Old Jul 16, 2007 | 01:49 PM
dwest1023's Avatar
Yes you can but its not worth $185 to do so.
Old Jul 16, 2007 | 03:45 PM
rza49311's Avatar
I used the following method found at post #1242 by bananafusion on my '06... not sure if it'll work for the '07 but i figured if the method was different than the one you've already tried then it may work.
https://acurazine.com/forums/showthr...&page=50&pp=25
Old Jul 17, 2007 | 02:38 AM
SoCaliTrojan's Avatar
Let me help you!
They can...other than the database changes, I think the audio screen looks different if you upgrade it.
I'd certainly upgrade if I knew they had fixed the daylight saving time problem.
As for updating the 07 navi, no one has been successful yet. I have an 06 so i can't play around with it...maybe someone soon will buy an 07 with some programming skills
MrHeeltoe
20
Feb 23, 2023 01:54 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
