Louder noise from engine after adding oil
Old Jun 17, 2007 | 11:39 AM
ivanloc07's Avatar
07 NBP 6MT
I have an 07 NBP with just over 3000k miles on it. Recently I checked my engine oil level and found out that it was just below the "low" mark. Because I am planning to use synthetic oil on my car, I added some Mobil 1 and the oil level ended up exactly at the "high" mark. However after doing so I noticed a slightly more noise coming from the engine. It's not a different noise, it's just louder than what it used to be.
I don't know if this has something to do with the synthetic mixing with the original oil that the car came with (I haven't done any oil changes yet) or maybe I filled the engine up with too much oil. Do I need to have my oil changed as soon as possible or drain some oil out to try to correct this problem? Or am I just worrying too much? Thanks for the help.
Old Jun 17, 2007 | 11:47 AM
carcrazyboy68's Avatar
well normaly u dont mix the 2 oils. i would get that replaced asap in my opinion.
Old Jun 17, 2007 | 02:15 PM
poltergeist's Avatar
Did you put the cap back on? That's the only thing I can think of that could cause additional engine noise after adding oil.
Old Jun 17, 2007 | 02:24 PM
ivanloc07's Avatar
07 NBP 6MT
Thanks. That's what I've been thinking. But at the same time, I don't want to change the break-in oil until at least 5k. I've been searching on the internet and I found this on the Mobil website:
Is it okay to mix conventional oil with Mobil 1?
Mobil 1 is fully compatible with conventional motor oils, semi-synthetic motor oils and other synthetic motor oils, should it be necessary to mix them. But the superior performance of Mobil 1 will be reduced by diluting it.
Can I mix one litre of Mobil 1 with three or four litres of conventional oil to enhance the performance of the conventional oil?
You can, but Imperial Oil does not recommend this practice. You give up much of the superior-performance characteristics of Mobil 1. The conventional oil in the mix will adversely affect the low-temperature flowability and high-temperature oxidation stability of Mobil 1. And while Mobil 1 is compatible with conventional motor oils, it has an additive package that has been specifically developed to work with its own high-performance components.
Any other input from you guys?
Old Jun 17, 2007 | 02:28 PM
ivanloc07's Avatar
07 NBP 6MT
Yes I did 100% sure. I should not have filled it up in the first place because the car was just doing fine before that.
Old Jun 18, 2007 | 03:13 AM
aaronng's Avatar
Driver/Detailer
No, you did the right thing. Driving around with low oil is worse than mixing the oils.
And if the noise increase is only very slight, it's not unusual. Mobil1 tends to run a bit louder.
Old Jun 18, 2007 | 04:51 PM
rb1's Avatar
rb1
Originally Posted by aaronng
Mobil 1 tends to run a bit louder.
Just curious, why would this be?
Old Jun 18, 2007 | 10:31 PM
aaronng's Avatar
Driver/Detailer
Not sure, that's what I've seen around most of the forums, even for other brands of cars.
Old Jun 19, 2007 | 06:09 PM
ATsxMan8305's Avatar
Agreed, you should never run your engine low on oil, even if you have to mix. My method is very simple - check your oil every time you fill 'er up with gasoline. For me, that is every 1-2 weeks usually. Checking tire pressure is another good thing to do, especially with significant temperature changes. Takes < 5 mins total. A lil bit overkill? Maybe, but the TSX is worth it
Old Jun 19, 2007 | 08:28 PM
rb1's Avatar
rb1
Originally Posted by ATsxMan8305
...Checking tire pressure is another good thing to do, especially with significant temperature changes. Takes < 5 mins total.
Those of us with an 07 TSX can check tire pressure in, oh, about 6 seconds.
Feb 25, 2020 09:57 AM
01CLOwner
Oct 9, 2015 01:07 PM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
Allen_442
Sep 8, 2015 06:01 PM
