Locked in Park!
Old Sep 10, 2009 | 10:01 AM
PNJBi's Avatar
Locked in Park!
Hi Guys,
So here's what happened -- I reversed into my parking spot this morning at work. I put it in to park and open the door to check if the guy beside me parked in crooked or was it me (it was the guy beside me) meanwhile the car is still running. I decide to move it back it bit more but when I go to shift the car from park to reverse it won't move. It moves only the amount that it would typically move when the brake is not pressed.
I've tried a few things
- turn off the car, turn it back on
- make sure that i've got the brake pressed in
- move the steering wheel around
I'm out of ideas -- any thoughts??
Thanks!
Old Sep 10, 2009 | 12:50 PM
Stevestr's Avatar
Looking at the '15 TLX
Check your owner's manual. There's a procedure for manually overriding the Park interlock that involves removing a cover near the shifter and inserting a screwdriver. That will temporarily get you out of park but you'll have to keep doing this until you get the car looked at.
Old Sep 10, 2009 | 04:32 PM
PNJBi's Avatar
Thanks Stevestr!
That saved me the cost of towing..
I think it may be linked to a switch or fuse. I noticed that the VSA light was off and also the brake lights weren't functioning. It's at the dealership right now, see what they say. Any idea how much a fuse will cost?
Old Sep 10, 2009 | 04:46 PM
litesout's Avatar
Oliver!!!
Probably not a fuse, probably the switch on the brake petal that tells the car when its being pressed. That would cause the park interlock to not function as well as the brake lights.
Old Sep 10, 2009 | 04:53 PM
PNJBi's Avatar
What would be the procedure to fix this? Replace the switch? Could you tell me where I can find the switch in the car?
Thanks!
Old Oct 6, 2009 | 05:36 PM
tl_ster's Avatar
I too have dis problem..my 00 tl will not shift into gear....i bought some new braking lights bulbs which i thought were tha problem and is not...so far researching on dis topics it seems like tha problem is tha braking switch....someone please me know if you guys have a solution to dis problem cuz last thing i wanna do is take it to tha dealership
Old Oct 6, 2009 | 07:11 PM
tl_ster's Avatar
found tha diy haha just gotta look around eh,,,https://acurazine.com/forums/2g-tl-1999-2003-98/diy-brake-switch-614710/
Old Oct 8, 2009 | 04:03 PM
PNJBi's Avatar
It was the brake switch -- the part is about $10 and its fairly easy to replace. I had the dealer replace it after convincing them that it was infact the brake switch and it's a 5 minute job.
Old Oct 8, 2009 | 06:50 PM
Tsx6363's Avatar
lol whoa 10 bucks? the guy ont he thread above bought it for 48 o_O where'd you buy it? part # for the tsx?
Old Oct 12, 2009 | 08:26 PM
Miamicarfan's Avatar
PNJBi:
What year is your TSX and how many miles does it have?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
