Location of Exterior Temp. Sensor?
Old Jan 24, 2008 | 08:44 AM
Dr. Evil's Avatar
You will do as I say
Anyone know where the external temperature sensor is located? I think mine is getting dirty or something as it is not accurate for cold temperatures anymore. used to work good.
Old Jan 24, 2008 | 08:51 AM
LukeaTron's Avatar
You can see it hanging down in the lower air duct on the front bumper. It's a black cylinder about an inch and a half long mounted horizontally just below the top of the opening. How much is it off by?
Old Jan 24, 2008 | 09:00 AM
SimpleWhite's Avatar
if you take your front bumper off, you'll see it clear as day attached to the frame of the car. If you have been in some type of front end collision than that might have cause the issue.
Old Jan 24, 2008 | 09:06 AM
Dr. Evil's Avatar
Temp sensor
Thanks for the help. No damage to the bumper or sensor. Typically below about 40F is off by about 5F. In years past, it was right on the money every time.
I am thinking it might be dirty or the connections.
So I have to remove the front bumper to get at it? Or is it easier then that?
Old Jan 24, 2008 | 09:30 AM
LukeaTron's Avatar
I think to remove it you might have to take the bumper off to get at the bolts. Other than that, it's right there when you look into that opening.
Old Jan 24, 2008 | 11:16 AM
Simba91102's Avatar
Old Guy
Yah, mine's starting to sh*t the bed too (05 w/ 65K miles). It reads a pretty consistent 2 degrees low. Used to be right on the money.
Old Jan 24, 2008 | 11:20 AM
nbtx's Avatar
still plays with cars
I think there is a recalibration procedure in the owner's manual.
Old Jan 24, 2008 | 12:18 PM
dwest1023's Avatar
you can recalibrate the sensor +- 5 degrees.
Old Jan 24, 2008 | 12:49 PM
Dr. Evil's Avatar
Calibration Procedure
Re-calibration -- ahh very nice. Is that in the owner's manual or shop manual?
If shop manual - could someone scan that section and post it?
Old Jan 24, 2008 | 03:12 PM
LukeaTron's Avatar
It's in the owner's manual. For the '04 it's something like hold down the trip odometer reset for 10 seconds and the display will start cycling from 0 to 5 to -5 and back to 0. You just let go when it's where you want it.
Old Jan 24, 2008 | 06:15 PM
jlukja's Avatar
FYI, if its in the owners manual then you can find an electronic copy of it in our FAQ section.
Old Jan 25, 2008 | 01:15 PM
rb1's Avatar
rb1
Mine (relatively new 07) seems accurate when it's "working", but sometimes I think it "freezes" and stops updating the temperature, just reporting the last reading received from the sensor.
It's also surprisingly slow to update given the amount of air that moves over the sensor. If it's in the 20's outside, it takes almost 5 miles of driving before it gets close to the right reading if it was 50 in the garage. Go figure...
Old Jan 25, 2008 | 02:44 PM
LukeaTron's Avatar
It's probably done on purpose so as to not be bouncing all over the place from localized heat pools hanging out on the pavement.
Old Jan 25, 2008 | 09:12 PM
rb1's Avatar
rb1
Perhaps, but today I drove home 12 miles (39F the whole way), parked in a 50F garage, and then went to dinner an hour later
It still read 39F all the way to the restaurant. But then went I get done and leave, suddenly it's 45F, 6 degrees warmer outside than in my garage...
RobbDizzle
Oct 15, 2015 11:16 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
ripit
Sep 26, 2015 06:19 PM
TL14
Sep 24, 2015 04:37 PM
joflewbyu2
Sep 23, 2015 11:16 PM
