Leak Help!!!!
Old May 17, 2004 | 07:35 AM
DjElucid's Avatar
Leak Help!!!!
Get this!
I turn on my AC for the first time this year, with my girlfriend in the passenger seat, she tells me my car is leaking water. I said WHAT!? I doubted her, but... I looked and and yes I see a piddle of water. Took a 3 hour drive this weekend and had to have my AC on. By the end of the drive, my passenger floor was soaked and submerged in water.
It's leaking out from the air vent under the glove compartment. Water is HOT when it leaks out.
Will call dealer today. Anyone know Acura's loaner policy?
Old May 17, 2004 | 07:46 AM
TSX CSI's Avatar
LOUD NOISES!!
That is very alarming, I have to look into that, i wouldnt really know because most of the time I drive, I am alone so i never really think to check the passenger floor..... But as per the Loaner issue.... My dealer (Bedford Acura, NY) said that they have to schedule you far in advance to make sure you get a loaner otherwise you are SOL. Apparently my seat transmission is/was broken, i had no idea, i dont move my seat all that often. And since this is an over night job, i requested a loaner. Needless to say the part came in 2 weeks ago, I cannot afford to leave my only means of transportation. Just food for thought that you might have to wait a few weeks to schedule a loaner, hope all works out....
Old May 17, 2004 | 08:21 AM
biker's Avatar
The AC system has no hot water in it - the only thing that has hot water inside the car is the heater exchanger. Did you never use the defroster? That uses the AC system and should have triggered this issue.
If it was a choice between a flooded passanger floor and no AC I would have taken the latter choice. As anyone would tell you, without replacing every fiber, a flooded car can never be made right.
Old May 17, 2004 | 12:05 PM
miner's Avatar
Re: Leak Help!!!!
Originally posted by DjElucid
Get this!
Sounds as if AC drain line is clogged or disconnected. It is the line that drains water to the garage floor after your TSX is parked.
Old May 17, 2004 | 02:09 PM
DjElucid's Avatar
I would much rather have no AC and I did turn it off, but it was raining and I couldn't see. So I had no choice, I tried turning it off a few times, but didn't work. I'll be calling them today.
Old Jun 2, 2004 | 11:52 AM
HCF's Avatar
HCF
'Insert witty text here'
Hey Dj, did you ever take your car to the dealer on this issue??
The reason I asked is a very similar thing happened to me I was driving around and noticed my car starting to sound like there was a fish tank in the dashboard. Then my AC fans started acting very strange. I asked my wife to check the floorboard on her side because I remembered reading this post and she said it was dry. Well to make a long story a little shorter, I went out the next morning and there was about 6 inches of water in the passenger side footwell. Sound bad? It gets better. Looks like it flooded my ECU so my car won't start. I finally got a tow to the dealer and they are looking into it.
Old Jun 2, 2004 | 12:13 PM
miner's Avatar
This is a text book example of what happens when the AC drain line gets clogged or disconnected - in your case it is clogged.
Old Jun 2, 2004 | 05:16 PM
sixspeed's Avatar
I second that. My friend recently had the same thing happen in his I35. It turned out to be a clogged drain. According to the guy who fixed this it was a spider ...
Old Jun 4, 2004 | 11:50 PM
DjElucid's Avatar
Hey Guys!
Just got back from Sunny California. I brought my car into the dealer last thursday before I left. Turns out the drain pipe was clogged. He said there were leaves in it or something. Simple problem fixed and then the dealer tried to sell me on the AC water filter or something for $77. He said it should be changed every 15k miles... that true? I denied it.
Old Jun 5, 2004 | 12:49 AM
tony4311's Avatar
I am Ahab!
Originally Posted by DjElucid
Hey Guys!
first time i've ever heard of a ac filter. I would'vd done the same
Old Jun 5, 2004 | 05:31 AM
bob shiftright's Avatar
The Voice of Reason
Hey Guys!
The Pollen Filter? Yes, according to the TSX Official Maintenance Schedule the pollen filter should be replaced every 15,000 miles "if the vehicle is driven mostly in urban areas that have high concentrations of soot in the air from industry and diesel powered vehicles."
I'd add: "Or if it's parked around trees."
I've replaced the pollen filter on my wife's Oddy twice so far (not a task for the faint-hearted!) and I was amazed by the amount of crud - leaves, pie needles, feathers etc. that had accumulated in the plenum chamber. It's not a stretch to see how the drain could easily clog.
I was also amazed that the Pollen Filter was a lot dirtier than the engine air cleaner!
Old Jun 5, 2004 | 12:35 PM
tony4311's Avatar
I am Ahab!
whoa
Old Jun 5, 2004 | 08:58 PM
The Voice of Reason
Originally Posted by tony4311
whoa
Maybe the pollen filter is a finer mesh than the air cleaner?
Anyway, on my Volvo they recommend pollen filters every 15,000 miles but engine air cleaners every 30,000.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
