Immobilizer Light Flashing
Old Apr 28, 2008 | 09:04 PM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
Today, I walk back to my car in the parking lot and I go to start it, but it doesn't fully start. The engine cranks, but does not go beyond that. I kept trying over and over, then I notice the immobilizer light flashing. So I flipped through the manual and it said that if this happens, the key isn't properly coded, or basically the car doesn't recognize the key and the fuel pump is disabled.
Thinking that it might just be my key acting up, I found a ride home and brought all my keys back to my car. Tried all of them and it was the same case, flashing immobilizer light. The thing is, all of my remotes work to unlock and lock the car, radio is fine and so is everything else except tat my car won't start.
Next step, I got my car towed to the dealership. Got it to the dealership right before their service department closed for the day. They tried to hook it up to the scanner, or what ever they use to diagnose problems, and said that they got a "communication error." I asked what that meant and he said that my ECU wasn't even communicating with their tool.
So they'll have to look more into it tomorrow. Hopefully the problem isn't too bad. What do you guys think may be the problem?
Quick Specs:
2004 TSX
6MT
133,xxx Miles
Hondata Reflash (2005)
Thanks in advance for any insight on my problem.
Old Apr 28, 2008 | 09:21 PM
visuelz's Avatar
East Coast Crew
From a technical point of view, it may mean that there is no power going to the ECU. Maybe there's a bad connection from the power to the ECU...hmm.
Old Apr 28, 2008 | 09:26 PM
nbtx's Avatar
still plays with cars
WAG: The ECU has taken a dump, or the ECU and the immobilizer aren't communicating. I don't have the FSM yet, but I think there is a serial data link connecting the various modules on the vehicle and the problem could be there too.
Old Apr 28, 2008 | 11:19 PM
JTso's Avatar
Let's hope the dealer won't wipe out your hondata reflash during the troubleshooting process.
Old Apr 29, 2008 | 12:43 AM
TSX 3Pedal's Avatar
What should I do if that happens?
Old Apr 29, 2008 | 07:23 AM
nbtx's Avatar
Good question - If the ECM has failed, the dealer will replace it with a new or rebuilt one that has the stock software. It's not likely the reflash will be wiped while troubleshooting.
Just to make you feel good: My 91 Corvette has its parameters burned into a plug-in EEPROM which you can swap into the new/rebuilt ECM so nothing is lost if you have a custom PROM. Newer technology ECMs have the memory chips wired in and accessible only with specific programmers which the DIY folks do not have access to. Honda/Acura has really clamped the lid on DIY access unlike GM, Ford and Chysler.
That's why you have to deal with Hondata ...
Old Apr 29, 2008 | 10:32 AM
JTso's Avatar
The TSX ECU doesn't have a removable EEPROM. If the dealer only needs to code the key/immobilizer portion on the ECU, the Hondata reflash will be fine. However, if the dealer tries to update the ECU with the newer version of software for troubleshooting, the Hondata reflash will be gone. Also, if the dealer replaces the ECU, the Hondata reflash is not transferred over to the replacement ECU.
Old Apr 29, 2008 | 04:27 PM
TSX 3Pedal's Avatar
If I end up losing my Hondata, do you think Hondata would perform the reflash for me again for free?
Old Apr 29, 2008 | 06:25 PM
visuelz's Avatar
East Coast Crew
Businesses like to make profit, so I highly doubt it. However, they may offer you a discount.
Old Apr 29, 2008 | 09:33 PM
nbtx's Avatar
That's what I said in an earlier post.
Old Apr 29, 2008 | 09:51 PM
TSX2345's Avatar
A DiRTBAG decal on my
Perhaps inqure with them directly
Old May 1, 2008 | 01:12 AM
TSX 3Pedal's Avatar
Update: I got my car back today. I'm glad that it was nothing serious. It was just basically a fuse that burnt out preventing my ECU from recognizing my key.
Old May 1, 2008 | 11:42 AM
nbtx's Avatar
Good news/bad news: Your vehicle is up and running////fuses don't "burn out", they blow because of an over-current condition - something made that happen and it will happen again.
Old May 1, 2008 | 04:46 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Glad to hear that it was something simple. I was worried for a second
Old May 1, 2008 | 04:47 PM
Mokos23's Avatar
that's a lot of miles
Old May 1, 2008 | 10:58 PM
SoCaliTrojan's Avatar
Let me help you!
Which fuse is able to partially disable an ECU?
Old May 2, 2008 | 01:01 AM
TSX 3Pedal's Avatar
What's a car for if it's not to be driven?
Yea, I just calculated my mileage, I average about 27,000 Miles per year with my 5th year of ownership coming up in June
Old May 2, 2008 | 01:03 AM
visuelz's Avatar
East Coast Crew
Use a fuse with a higher rating amp
TSX 3Pedal's Avatar
I'm not sure which specific one, but it was a fuse from the fuse box under the hood. The dealer gave me a couple of extra fuses, just in case. The fuse is blue in color, I don't know if that helps any in locating which specific fuse it was that burnt out.
Old May 2, 2008 | 01:44 AM
Mokos23's Avatar
dang man, how many times do you gas up a week?
Old May 2, 2008 | 03:00 AM
TSX 3Pedal's Avatar
Once a week nowadays, since I don't commute as much as I used to
Old May 2, 2008 | 09:41 PM
TSX 3Pedal's Avatar
Alright so I finally checked out which fuse it was that burnt out.
Fuse #8
Amps: 15A
Circuits Protected: FI ECU
Anyone have any thoughts as to what caused this circuit to short out?
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
Greengecko
Sep 16, 2015 08:19 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
HeloDown
Sep 8, 2015 06:51 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
