Help, just install intake
Old Feb 13, 2007 | 04:48 AM
donaldwong1986's Avatar
I just got a new intake and install it.
But after i follow all the instruction and set it up, when i start my car, the engine light just suddenly lights up, did anyone of you guys have this problem also when u change your intake?
I had a 04 TSX AT.
can anyone please help, urgent.
thanks a lot.
Old Feb 13, 2007 | 06:13 AM
moda_way's Avatar
Which intake?
Old Feb 13, 2007 | 06:20 AM
aaronng's Avatar
Driver/Detailer
You remembered to connect the intake air temperature sensor properly?
Old Feb 13, 2007 | 06:57 AM
moda_way's Avatar
There really isn't much to fk up on this install.
Moving to Problems section.
Old Feb 13, 2007 | 09:30 AM
jlukja's Avatar
It can't be the Icebox because there is no sensor to disconnect in that install.
Old Feb 13, 2007 | 11:01 AM
Comptech-814's Avatar
MACura TSX
this is the most helpless thread ever
which intake!
Old Feb 13, 2007 | 12:57 PM
My intake is Weapon R with the dragon style.
But when i take out my OEM intake, there are no sensor except for just one blacck plug in.
is the the aoxgen sensor?
but my intake doesn't have anywhere to plug that in.
so where should I plug that sensor to if that black plug in is the one?
Old Feb 13, 2007 | 02:06 PM
hrj's Avatar
hrj
the black one is IAT sensor.
from JTso's K&N CAI review thread. the circled one is the IAT sensor.
Old Feb 13, 2007 | 02:35 PM
clee109's Avatar
I Quit
spray super hold hairspray on the sensor, reinstall it, disconnect the battery, then recconect it, done deal
Old Feb 13, 2007 | 03:08 PM
JTso's Avatar
Old Feb 13, 2007 | 04:29 PM
Reach's Avatar
lol... don't do that.
Here's a question, does this "weapon r" intake have the correct 2 ports for the sensors, and does it seem like they fit appropriatly? The weapon r intake is an unknown quantity around here. If I were you, I would have gone for a more name-brand model.
Old Feb 13, 2007 | 04:32 PM
clee109's Avatar
I Quit
JTso - f the sensor (circled above) is a bit out of perfect seating it will trip the check engine light. The hair spray works as a "glue" which will keep it in under most driving conditions and you can still take it out easily and doesn't effect the sensor at all and wont crack the rubber grommet. Once the check engine light is on you have to disconnect the battery to reset it (that's why you disconnect the battery befor installing in the first place) then reconnect it then start the engine and viola no more check engine light.
My friend had an AEM V2 on his RSX that never snugly held in the IAT, so I did that fix and the check engine light never came on again.
Old Feb 13, 2007 | 05:06 PM
hrj's Avatar
hrj
K&N intake's fitment is the best I've seen on TSX. The IAT sensor is mounted perfectly on the intake tube w/ rubber grommet. It won't trigger a CEL unless you unplug it.
Old Feb 13, 2007 | 06:14 PM
moda_way's Avatar
Interesting fix, though it seems a little
I'm just not sure what effect the hair spray will have on the sensors correct reading of air temp if there is a coating on it.
Old Feb 13, 2007 | 06:49 PM
JTso's Avatar
The IAT will not trigger a CEL as long as it is connected to the wiring. It's nothing more than a thermistor inside the housing. In fact, you can leave it out dangling but connected and it still wouldn't trigger a CEL. All it does is detecting under hood temp instead of intake manifold temp. However, I would simply get a proper size grommet and install it where it should be to allow the correct detection of air temp.
cycdaniel
Dec 17, 2019 10:58 AM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
james357
Feb 13, 2016 02:37 PM
nanos
Nov 12, 2015 08:41 PM
Abe_Froman
Sep 16, 2015 01:27 PM
