Heater/ac blower problem
Old Nov 9, 2009 | 02:31 PM
tony366's Avatar
6th Gear
I have an 04 TSX heater fan just quit checked fuses seem fine removed the blower blower runs connected to 12v any ideas?
Old Nov 9, 2009 | 03:03 PM
poltergeist's Avatar
If the blower motor works connected directly to +/-12V, and you have +12V available at the connector that plugs into the motor, then it's almost certainly a failed blower transistor that provides a variable ground to the motor to control it's speed.
Old Nov 9, 2009 | 03:25 PM
tony366's Avatar
6th Gear
Thanks where is the blower transistor and can it be replaced?
Old Nov 9, 2009 | 07:07 PM
It's mounted in the ducting under the right side of the dash, behind the glovebox. Relatively easy to replace.
Old Nov 10, 2009 | 08:06 AM
tony366's Avatar
6th Gear
Thanks il give it a try.
Old Nov 11, 2009 | 05:41 PM
tony366's Avatar
6th Gear
I removed the glove box and can't seem to find it can you be more specific.
Old Nov 12, 2009 | 02:32 PM
You don't have to remove the glovebox. The transistor is low in the HVAC ducting to the left of the blower motor. Has a 4 pin connector and is mounted with 2 screws.
Old Nov 12, 2009 | 03:24 PM
tony366's Avatar
6th Gear
Thanks got it where would be the best place to fine a replacement?
Old Oct 5, 2010 | 04:04 PM
killerjonan's Avatar
8th Gear
OK, so I have the same problem here and have a new transistor on hand. I took off the panel under the passender glovebox and can see the transistor to my far left. However, there is a plastic flap in my way so I cant really reach the screws or the connector.
Can anyone give me some step by step instructions on how and what to remove so that I can take this broken transistor out and replace it with a new one?
Thanks!
Old Oct 6, 2010 | 01:03 AM
8th Gear
Nevermind the above. i figured it out, just had to use a longer philips screwdriver to reach the far screw.
Replaced it with a new transistor, and blower started working again!
Thanks anyways.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
