2005 Tsx Problem
2005 Tsx Problem
Hello everyone,
Im new to the board. My wife has a 05 TSX with a auto tranny and between 20-30 mph the transmission has a bad chattering. Is there a fix for this or is it just hers. Would really like some of yalls help.
Phillip
Phillip
mate thats rubbish its fluid and needs changing,the work an auto does is immense i change manual gear oil every 25k personally i would be changing atf a lot sooner, if you read the same abouy engine oil would you be inclined to leave it in there for longer. at the end of the day i have never ever heard of anything failing due to changing fluids to soon, i have so many taxi friends who fork out for complete transmissions 8k for lexus gs430,when 100euro on changing the filter and atf would keep the auto in tip top shape. the problem over here is main dealers dont touch auto transmissions its a speicalist job
Drain and refill, do not use a machine to flush. Honda strongly recommends NOT flushing the transmission. There should be a DIY on here somewhere for the drain and refill, or take it to the dealer. I think you do it 3 times, driving around a couple miles in between each refill.
A change every 40-50K is still more often than speicifcations call for. Driving style will dictate how often it needs changed. If someone is really hard on their transmission or doesn't shift properly, it would need to be changed (along with other components) more frequently, but an average driver doesn't need to change the fluid as often as 25K or less.
handsom-hustla
Nov 13, 2015 05:04 PM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
ivegotthenav
Sep 11, 2015 07:51 PM
