Grinding/Vibration when braking!
Old Feb 20, 2005 | 04:23 PM
patch's Avatar
Angry Grinding/Vibration when braking!
I've searched but found nothing. When I brake hard or brake while turning at low speeds, there is a grinding sound and vibration in my brake pedal. The sound seems to be coming from the front of the car. Not sure what could be causing this... any info/advice?
Old Feb 20, 2005 | 04:43 PM
CGTSX2004's Avatar
Check the info here:
https://acurazine.com/forums/showthr...ght=rotor+warp
Old Feb 20, 2005 | 04:52 PM
patch's Avatar
So my problem is warped rotors? Do I just take it in to Acura to get it fixed?
Old Feb 20, 2005 | 04:54 PM
CGTSX2004's Avatar
Yes. If you have only a few thousand miles, you might be able to get it done under warranty. If you have a lot of miles on the car, you will need to pay to have this done.
Old Feb 20, 2005 | 05:16 PM
patch's Avatar
I have 1500 miles, so hopefully it'll be covered. Thanks CG.
Old Feb 20, 2005 | 05:18 PM
CGTSX2004's Avatar
Before you go, consider printing this out and bringing it with you...
http://www.alldata.com/TSB/01/04013446.html
Highlight item 4.
Old Feb 20, 2005 | 06:01 PM
poltergeist's Avatar
Are you sure you're not activating the ABS??? Not that hard to do especially on wet or loose road surfaces.
Old Feb 24, 2005 | 08:10 PM
aaronng's Avatar
Driver/Detailer
I get this after washing my car when braking to a stop on a downward incline. After that it doesn't happen again. Could it be the rust being wiped off by the brake pads?
Old Feb 24, 2005 | 09:40 PM
patch's Avatar
So I went to the acura dealer and they said it's not warped rotors. They said it was ABS activating, but i get grinding/vibrations even through the gas pedal sometimes. But both the grinding and vibration only comes when I'm backing out of my driveway and my first stop sign, and it completely stops after i start driving.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
