Flat Tire Blues
Old Mar 16, 2007 | 09:22 AM
jm_tsx's Avatar
6th Gear
Flat Tire Blues
I got a flat tire by running over a nail in the street. Do you think I need to bring it to the dealer to plug the hole, or can my mechanic take care of it?
Old Mar 16, 2007 | 09:30 AM
jerzpwr's Avatar
a local shop should be able to fix you up.
Old Mar 16, 2007 | 10:30 AM
PWPTSX's Avatar
if it's only a small nail, i will just fix it myself using the flat tire kits
Old Mar 16, 2007 | 10:53 AM
LoveMyTL-S's Avatar
Most places charge about $10 to plug the tire.
Old Mar 16, 2007 | 12:50 PM
rb1's Avatar
rb1
If you're talking about using a can of sealant that you spray into the tire, don't do this in a 2007 model or you will destroy the tire pressure monitoring sensor. $$$ to replace.
This is specifically mentioned in the owner's manual.
Old Mar 17, 2007 | 03:20 AM
SoCaliTrojan's Avatar
Let me help you!
The dealer charges $15, and local shops may charge around $5 to $10. The gas station near my university would charge $5...and garage shops near my house charge $10. Just drive by a tire shop or a gas station that has a garage
Old Mar 17, 2007 | 03:27 AM
PWPTSX's Avatar
nah i never use those things.....i use the long brown sticky thing that you fill the hole with.
Old Mar 17, 2007 | 07:40 AM
mg7726's Avatar
She said: it's GINORMOUS!
if it's not on the sidewall, it's cheap to patch up.
Old Mar 17, 2007 | 08:41 AM
TSXHunter05's Avatar
I had the same issue, took it to an acura dealer that I didn't even buy the car from they plugged it and put it back on my car and put the spare away, charge=absolutley nothing not a dime!!!
Old Mar 17, 2007 | 11:10 AM
JTso's Avatar
The proper method is to remove the tire off the rim and patch from the inside. The lazy way is to plug from the outside and potentially damage the steel belt structure by inserting the tool. I would bring it to a tire shop.
Old Mar 17, 2007 | 01:58 PM
Ruserious's Avatar
6MT G37
I got a flat today on my sidewall and it was unrepairable. I just came back from the dealer where i payed $250 for a tire.....
Old Mar 17, 2007 | 03:55 PM
gtg710w's Avatar
06 GBM AT TSX + 35% TINT
if you're a costco member they fix it for you for free of charge.
Old Mar 17, 2007 | 05:21 PM
JTso's Avatar
Does that apply to tires not purchased from Costco?
Old Mar 20, 2007 | 01:52 PM
zooter's Avatar
Owner - Operator
I'm pretty sure that Costco will ONLY repair tires that you've purchased from them.
Old May 4, 2007 | 11:20 PM
gogozy's Avatar
thanks for the tips...
just found out one of the tire got a screw on it and will need to have it repaired tomorrow morning.. hope it's repairable.
TLDude876
Dec 28, 2016 03:18 PM
lland
Oct 4, 2015 04:47 PM
fallacy
Sep 4, 2015 10:15 AM
