Dealer Wrecked My Engine?
I had my 2004 TSX (6MT, Carbon Grey, No Navi) in for its 40k service yesterday at a local dealer. I drove the car for about 20 miles before returning home. When I pulled into the garage, I saw a 3" wide solid band of oil on my driveway. Upon a quick inspection, the oil in my TSX was completely depleted. Interestingly, though, neither the oil nor check engine light came on.
I immediately had the car towed to the dealer, and they admitted fault. They are currently "evaluating the situation." Here are my questions:
- Given the above, what is the likelihood that damage was done to my engine? If not immediate, can damage surface later?
- Should the dealer give me a new engine or do an engine rebuild? If so, how does this affect my resale value? Would an Acura dealer take my car in on a trade if I had a rebuilt engine? If so, for how much less?
- Is there history of Acura doing buybacks on cars that they wreck?
What's my best recourse in this situation? The dealer was very apologetic, so the ball may be in my court to make the necessary demands.
Assuming that your oil pressure light functions properly (ie last time you started it did you see it on and then shut off) then I would say given that it didn't come on during your drive home that your okay.
Asking the dealer to do anything advanced, like overhaul/replace engine will spell trouble for you.....the best mechanics work for themselves, they can make more money that way - the one's who rush and make there money that way or are crappy work at the dealers....I would suggest you ask them for a credit toward future service and that's it.
^^ Agreed. Ask for an extended warranty for the engine instead (because they messed up), + free servicing (for causing you trouble). I'd say an extension of 2 years on the engine alone is reasonable.
One of the things they should determine, having your car now, is how much oil was left in the oil pan. That'll give you a good idea of whether you can expect damage from oil starvation. A uoa is also a really good idea, if you can get a sample of the oil that was in your car.
For those of us changing our own oil, this is a cautionary tale about always making sure the old oil filter gasket is on the old oil filter when you remove it. Likewise the drain plug crush washer, make sure you account for it and replace it every so often.
Good luck negotiating with them for some peace of mind.
Originally, they didn't admit fault, but rather said that if it WAS their fault, that it could be very serious and they'd do what it takes to rectify.
I then took them over to the parking spot where my car was sitting after the service when I went to pick it up. Lo and behold, there was a lake of oil on the concrete and that same suspicious 3" band leaving their parking lot. The service advisor then said that they absolutely should have noticed that (a) when driving the car out of the service bay (b) into and out of the car wash and (c) when I was pulling out, as the SA walked me out the door.
I have pictures of the dealer lot just in case it ever comes into question where the problem started.
Get the oil filter off the car and take it to a reputable machine shop that deals with racing engines. They will have a special tool for cutting the filter open where you can check for signs of metal and bearing material.
If you don't find anything you should be ok. Refill it with oil, and run if there is no noise, or knocking under load, you should be OK. I'd recheck the filter again for contamination in about 1000 miles and it probably wouldn't be a bad idea to have the oil check after you put some miles on it.
If the motor is junk. I'd want a new long block from Acura, I'd wouldn't want or trust the dealer to rebuild it. The would most likely farm it out to a machine shop and IMO it just wouldn't be the same as a factory built motor.
This is one of those things (checking for the filter gasket and drain washer) that takes 1 horror story to make you check every time. Since the crush washers are aluminum, 2 uses is all I've found to be "safe". You can probably get away with more, but I would never suggest it. I used to change my father's Nissan Maxima and it used a cooper crush washer that would crush in such a way that you couldn't reuse it.
If the oil light never came on, dosent that mean the pressure was adequate enough during the time he was driving with low oil?
Yea, its F'ed up the dealer did this, but I dont see why it would cause any permanent damage.
Thanks for all the advice.
The dealer has thrown away the filter and the residual oil in the pan without providing any analysis. As far as I'm concerned, that only makes the case against them stronger. If they had run the necessary tests instead of just "listening to the engine" they'd have more of a leg to stand on when they assert that all is well.
Originally Posted by joerockt
Leg to stand on with who? Are you taking legal action?
In all likelihood, yes. I have already had the papers drawn up, but haven't filed them yet. I gave them until Friday to come up with a solution.
Have you talked to the owner or the general manager? Tell them your concern about possible internal damage. Give them your remedies, most dealers are reasonable. An Acuracare extented warranty should give you peace of mind.
I can't believe you're even thinking about legal action. I know the dealer f***ed up, but come on you had enough oil in your engine that it even leaked onto your driveway after 20 minutes of driving. Your engine didn't overheat and your oil-pressure light never came on. That's concrete-proof for the dealer's lawyers to win the case.
All you can get out of this whole thing is maybe a few free service sessions and some sort of an extended warranty(if at all).
Your engine was not damaged and the dealer knows this, so don't expect much out of them.
1. They had no way to prove how much oil was left in the engine.
2. There is a very real possibility of engine damage even though there may not be signs of it yet.
i have free oil changes for life cause my dealer did something like this. they forgot to tighten the drain plug.
Originally Posted by SPARKIE
So what happened at the meeting? Please update.
- Extension of powertrain warranty to 7 yr/100,000 TVM
- Upfront cash settlement
- Handful of free oil changes
The dealer also mentioned that they've added some measures to their oil change process in an effort to head off future situations like this.
All in all, I feel like the dealer stepped up and took care of me as a customer, which is very much to their credit, both in terms of future service visits, and ultimately when the time comes for me to buy my next car.
Good job on the deal - sounds like they did a good thing and tried to keep you as a customer. Always a good sign.
In fact, I'm pretty sure that companies like to hear about this, normally, because it gives them a chance to correct future problems. Sure, it shouldn't have happened in the first place, but it is a place of improvement.
Was the cash settlement for the lawyer?
Scary stuff, I wonder if the oil leaks right away, because then If it was right after the oil change, maybe you can catch the leak at the dealership.
I'm going to check under my car next time right after an oil change for leaks.
I'll DEFINITELY check for drips before I drive too far next time!
