A/C belt tensioner
Old Aug 7, 2008 | 01:44 PM
chinoz's Avatar
A/C belt tensioner
Can anyone tell me what this is?
I've been told I need to replaced and quoted 4 bills (P&L). Sounded kinda steep.
Thanks!
Old Aug 7, 2008 | 02:04 PM
MMsTSX's Avatar
JDM Addict
it's basically a pulley that sits in the loop of the A/C belt that sets the tension
on the belt. If the tension of the belt is wrong, the system won't work properly.
is your whole A/C system not working?
I can't find that particular part for sale.
just the whole compressor, or condenser, or whatever.
Old Aug 7, 2008 | 02:05 PM
chinoz's Avatar
One other thing... I read the Warranty manual and it says "Timing belt, balancer belt and tensioner" 5 years/100k warranty. is this ac belt tensioner part of that?
thanks
Old Aug 7, 2008 | 02:11 PM
chinoz's Avatar
excuse my ignorance, but is a/c air conditioner?
if it is then it works...
How I found out about this issue was that I there was a clicking noise from the front/passenger side when I was turning making right turns.
Old Aug 7, 2008 | 02:59 PM
LukeaTron's Avatar
I fail to see how a clicking noise when turning would implicate the belt tensioner. There is only one belt tensioner in the car so that has to be what the warranty is talking about. I'm pretty incredulous about it's relationship to the problem you're describing though.
Old Aug 7, 2008 | 03:02 PM
PACman's Avatar
thanks
I thought our cars had a Timing CHAIN, not a belt.
Old Aug 7, 2008 | 03:15 PM
chinoz's Avatar
beats me too.. that's how I described the problem to the dealer. It happens when I make right hand turns, I hear a clicking noise near. I thought it had something to do with the suspension.
They diagnosed it as the a/c belt tensioner needs replacing.
Old Aug 7, 2008 | 03:17 PM
chinoz's Avatar
I think it's a chain. I had that replaced recently too.
probably just bad wording in the warranty booklet.
Old Aug 7, 2008 | 03:22 PM
PACman's Avatar
How weird. I would of guessed CV boot(s).
Old Aug 7, 2008 | 03:44 PM
chinoz's Avatar
My dealer tells me this specific part is only covered 3 year/60k warranty (Canada)
going to call Acura customer relations to confirm.
Old Aug 7, 2008 | 04:24 PM
LukeaTron's Avatar
I read your original quote from the warranty completely wrong. It's been a long... well last few months. Anyway, the warranty seems be talking about cam timing components (it is a chain in this car) rather than accessory components.
Why was your timing chain replaced? That should easily last the life of the engine.
Old Aug 7, 2008 | 05:34 PM
chinoz's Avatar
my chain was replaced because the odom was bouncing off 500rpm when idling, almost like it was going to stall.
What I got replaced was
-Tens assy, c-cha
-Guide comp, c-ch
-arm comp, ch-chai
-timing chain
-guide b comp, c-
-sensor assy, cra
Old Aug 7, 2008 | 06:20 PM
MMsTSX's Avatar
JDM Addict
wouldn't "Tens assy" have something to do with the Tensioner?
a tensioner has nothing at all to do with turning....
this is strange.
Old Aug 7, 2008 | 07:48 PM
chinoz's Avatar
I don't know if there's two tensioner's.. "Tens assy" and "Ac belt tensioner"?
to be honest I'm not sure it does have anything to do with turning. I just hear it when I'm turning right at slow speeds where the engine doesn't drown out the noise.
It's like a clicking or knocking sound.
Old Aug 8, 2008 | 10:31 AM
LukeaTron's Avatar
There is a chain tensioner for cam timing chain (you need to take things apart to see it) and a belt tensioner for the accessory belt that you should be able to see clearly. Did replacing the chain fix the idle problem? I'm hoping they came to that conclusion after testing a bunch of stuff because it's a very unusual part to have problems with.
The problem you are describing now sounds much more like a CV joint, a wheel bearing or something out of spec in the suspension. Maybe there's technical details your leaving out but if there's not, this shop sounds like they're just making random guesses about your problem. Guesses that don't even make sense.
Old Aug 8, 2008 | 10:47 AM
LuvMyTSX's Avatar
In my opinion, it sounds like you are getting ripped off for a repair that they are making up on their own. I'd take it to another shop for a 2nd opinion.
Old Aug 8, 2008 | 10:57 AM
chinoz's Avatar
it's my dealer.. haha
they've been pretty good at doing warranty work for me so far, but I'm coming up to the end of the my warranty.
I'm going to take it to a local shop just to confirm what the issue is.
Thanks everyone.
Old Aug 8, 2008 | 10:58 AM
chinoz's Avatar
Oh and yes the chain replacement did fix my idle problem, but they said originally it was some sensor that had an issue and just replaced the above list with it.
Old Aug 8, 2008 | 11:01 AM
chinoz's Avatar
I also dunno if I'm leaving out any technical details.. not car savvy as you can tell.
I just know what I hear.. nothing feels wrong with the car. I wanted to check it out because I was still under warranty for major components.
Old Aug 8, 2008 | 07:29 PM
240sx acura tech's Avatar
acura master tech
remember since the car is in warranty an complait that is recorded will still be fixed after the warranty is up . so i would let the dealer handle it. also if the tensionor is broken you
will notice that it vibrates alot. most def when the a/c is on. you may here it when turning but only at stop and pulling into parking spots ,this is when the power steering is under the most load, putting more strees on the tensionor
Old Aug 10, 2008 | 08:09 AM
chinoz's Avatar
thanks for the info... I almost never have the a/c turned on though
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
brboy
Oct 5, 2015 11:34 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
hashbrown
Sep 29, 2015 12:13 PM
