Brake problem: Is this normal?
Old May 1, 2009 | 01:07 AM
xSteveO325's Avatar
Changed out my rotors and pad a couple weeks ago, noticed that the pad wasn't making contact all the way on the rotor. I'm not sure if I installed these things wrong or this is normal
Here's a few pictures to show you what I'm talking about
excuse the ugly calipers, owner before me obviously had no taste
Old May 1, 2009 | 06:25 AM
moda_way's Avatar
Contact patch is determined by the design of the pad. If the pads are narrow, then that is the contact patch you've got. Does this differ from the passenger side? Could be a caliper that needs to be rebuilt/replaced, could be your installation, etc etc. I'd be concerned though... seems small to me.
Old May 1, 2009 | 02:46 PM
npolite's Avatar
The rotor is damaged so I would be very concerned about who did the job. Get it looked at ASAP. It may be a minor issue but you never know what is wrong.
Old May 1, 2009 | 03:28 PM
nbtx's Avatar
still plays with cars
If both sides are the same, you're good to go. Minor scratches are not a problem.
Old May 2, 2009 | 10:20 AM
xSteveO325's Avatar
where's the damage at? I did the job. The pads went in place just find, both calipers seem to be working (no pulling). I did notice that the pads don't reach all the way down to the hub, so I don't think it's a problem of uneven pressure, just simply narrow pads. The brakes work fine, actually worked better than before. I'm going to go talk to Autozone and see if they think it's normal, they are the ones who gave me the pads, so I'd assume they'd be at fault if they were the wrong ones
SidhuSaaB
May 30, 2020 12:40 AM
lanechanger
Oct 13, 2015 10:56 AM
wubly
4G TL Problems & Fixes
Oct 6, 2015 02:45 PM
ripit
Sep 26, 2015 06:19 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
