Auto dimming mirror
Old Sep 11, 2004 | 07:42 AM
o3jeff's Avatar
Auto dimming mirror
Has anyone had a problem with their mirror dimming fading in and out? If so is there a quick fix?
Old Sep 11, 2004 | 06:59 PM
sigmachi96's Avatar
A-spec Arctic Blue
Not me. Did you try turning off and then back on?
Old Sep 11, 2004 | 11:03 PM
o3jeff's Avatar
Tried that and also unplugged it in the back of the mirror and plugged it back in.
Old Sep 17, 2004 | 09:04 PM
Doctor V's Avatar
Mine's been doing that lately too, when it's dusky or overcast, exspecially when I pass under some trees. It'll get stuck for a while on dark, then lighten up, and I've noticed it flickering sometimes. I planned to ask the dealer about it next time I take it in for service.
Old Sep 17, 2004 | 09:09 PM
jcg878's Avatar
Obnoxious Philadelphian
No problems, except with my parking hangtag
Old Sep 17, 2004 | 11:32 PM
lokman's Avatar
Boy Genius
There have been problems with the auto-dimming mirrors losing their ability to dim on the second-gen TLs. It seems to happen over time. I had this happen to mine. Maybe try taking it into the dealership and have it replaced under warranty?
Old Sep 18, 2004 | 07:03 AM
o3jeff's Avatar
I stopped by the dealer other day and they are going to swap it out when they get one in. I do have my windows tinted (35%) could that affect the auto dimming?
Old Sep 19, 2004 | 08:06 AM
achan268888's Avatar
so far, my tsx is great. only had minor problem. is the driver side door mini movements to make noise on bumpy roads. and center wheels' mini cap blk A is fading out
Old Sep 20, 2004 | 01:27 PM
speedyturtle's Avatar
Is there a way to make the dimming more sensitive??
I have 20% tint and it doesn't seem to recognize headlights from
behind as well now.
Old Oct 9, 2004 | 11:28 AM
A-Q-R's Avatar
Probably u hook some tags behind your rear view mirror.
There's a sensor behind the mirror. It detects if it's day or night by getting input of the light intensity from the front and regulate it with coming light intensity from the back.
Tinting window will normally do nothing different unless you tint your windshield. You will see the same brightness as before..but since you tinted the glass, the mirror might not dim as much as before(but you still see the same brightness),...but it's yourself that psychologically affected because you got used to the dark environment in the car....well..think about it
Old Oct 9, 2004 | 12:33 PM
slo007's Avatar
Master in Science
There's a sensor on both sides (front and back). Tinting could in fact affect the performance of the sensor pointing to the rear of the car.
I just wish the side view mirrors dimmed like in the Audi A4.
What I wouldn't do for a dimming mirror that reacted to the sun in the back of the car!!!
Old Oct 9, 2004 | 11:27 PM
VeniceBeachTSX's Avatar
Tuxedo Cat
The mirror reacts to the difference between the light in front and the light from behind. If it's dark in front (as it would be at night) and bright from behind (when there are bright headlights behind you) it'll dim the mirror. If you tint the rear windshield, you've already reduced the amount of light coming in from behind, so the mirror would dim a bit less.
One way to "balance" things might be to tape a small piece of tint film over the front sensor.
Old Oct 10, 2004 | 08:00 AM
Doctor V's Avatar
Of Course!
Thanks to your replies, I moved my hang tag and the mirror works fine again. The tag must've shifted enough to block the back sensor. At some point, I knew about the sensor in the front, but I didn't put two and two together.
Thanks for the tip!
Old Oct 11, 2004 | 05:02 PM
Tech SX's Avatar
It is normal for the mirror to adjust the tint level.
It only dims out when it senses light going into the sensor, for example, when a car is directly behind you. However, if there is no glaring light, the mirror would brighten back up. You can test this out by shining a flash light at the sensor, be sure to have the headlights on though. I think the mirror is activated by the headlight switch, but dont quote me on that.....good luck
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
malvothegreat
Sep 29, 2015 12:38 AM
