Replacement O2 sensor?
I'm scanning the net for parts (work hobby) and I came across this:
http://www.car-stuff.com/mmparts/acu...en_sensor.html
I had heard Bosch makes replacement sensors, but other than breaking one (Colts), why would you move to aftermarket? Also I'm wondering what the deal is with the generic looking $30 O2 sensor. Thoughts?
Aftermarket O2 sensor is usually cheaper than OEM. However, you have to make sure they are compatible. The TSX primary O2 sensor is a wideband sensor whereas most O2 sensors are not. The same site in your link also has a 1, 2- wires O2 sensors for the TSX which definitely will not work.
Other O2 sensors
Other O2 sensors
I forget how many wires ours is. It might be 4, but I'm not 100%.
You can reach the O2 sensor harness from the engine bay. Just look for a blue wiring running up from your header apipe. Check how many wires it has.
Looks like my O2 sensor is shot. I'm trying to figure out replacement options at the moment. Besides the $200 one directly from the dealer, are their any aftermarket ones that I can use? I would just cut the wiring off my current O2 harness and just solder up the new sensor to my old wiring harness.
Has anyone found any options?
Thanks!
Thanks!
Other O2 sensors
Other O2 sensors
Thanks!
Thanks!
Johnny, would the 4 wire sensor in the link above work for our car? I called the website to verify that it was a wideband O2 sensor. The answer I got was that it was, but the tech didn't sound too sure, and I have my doubts.
I can get a wideband o2 sensor from an 05 Type S for around $80 shipped. Any idea if that would work? Thinking about just cutting the wires and splicing into the TSX's O2 sensor harness.
I'm still strongly learning towards OEM though. I'll probably just bite the bullet.
Going to meeting up with Imaginary17 this weekend to swap my primary O2 sensor with his and verify that this is my problem. Special thanks to him!
Just found this replacement sensor on Ebay and I think I'm gonna go for it if I need a new one.
http://cgi.ebay.com/ebaymotors/ws/eB...m=190030722186
The seller will guarantee it for 60 days. I emailed him directly and he says it will work. He has good feedback and sells a lot of of O2 sensors, so I think it's worth the risk. Also, a new one from the dealer is $200 and this one is only $20.
Anyone see any reasons why this wouldn't work?
It wouldn't work because it's not a wideband sensor. Denso doesn't even make an O2 sensor for the TSX. The one on ebay is for non-wideband applications.
http://www.densoproducts.com/product...ctCategoryID=2
Originally Posted by lcrazyaznl
Yea it started throwing high and low voltage 0138 0137
Dealer won't warrenty becasue of the aftermarket cat =\
CL9 ABP
i wish but the highflow cat is welded to the pipe since it fixed the gap after the headers install.
There was a post a bit back when I installed the cusco bar that they extended the exhaust system back so my tips stick out now rather then hide.
General question about the primary O2 sensor....how long is it's life? (I read someone say about 50K) I'm at 58K, and I'm throwing a CEL, which I think the sensor is the problem due to some lagging throttle response.
Go see someone with an ODBII code reader and pull the code(s) for the CEL. Then search the Net for "Honda CEL codes" and look for your code. Or look in the Helm's manual if you have one.
CL9 ABP
I had a p 0138 and a p 0137
Low and high voltage on circuit
bank 1 sensor 2 i think.
So we swapped the 02 sensor on the cat and it looked old pretty much.
i'm at 50k now.
i'm at 50k now.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
You might even be able to get the dealer to replace it under warranty if they are cool. Is yours messed up |crazyazn|?
