FYI : For anyone doing a engine swap
I have swapped the 04-05 TSX K24 with the 06-07 revised TSX K24 with more horsepower. It is a noticeble difference and was well worth it! After consulting Hondata I was able to use the same reflash I use with the older original motor! To top it off I sold the 04-05 K24 to a Civic guy for the same amount I bought the new motor for! You have to make small mods to make it work but for the most part it goes right in ! If you guys need any advice just ask.
Originally Posted by TacoBellSauce
goddamn
u swapped a whole motor just for 5 more hp?
i dont think u had to do all of that, coulda just gotten headers and the exhaust for more hp
I had a mis shift and bent a few things I would say. So instead of using the same engine I upgraded to the newer motor. And no i didnt upgrade for 5 hp! For one that motor has about 15 more hp and has many upgrades over the 1st gen K24. 15hp in addition to many other mods which makes a big difference.
The 06 TSX has the following improvements:
Increased intake flow:
Intake valve + 1 mm oversize
Intake cam High lift lobe with 0.9 mm more lift and 12 degrees more duration
Throttle body increased from 60-64mm
Radius on some intake pipes increased from 70-80mm
Increased exhaust flow
Exhaust Head pipe increased from 60-65mm
Higher flow catalytic converter
Main (single) exhaust pipe increased from 54-57mm
Rear (twin) pipes increased in diameter from 42.5 to 45mm
Block improvements:
Additional air passages in crankcase for reduced pumping losses
Other
Stronger connecting rods
New crankshaft with more counterbalance weight
Revised pistons with more valve-piston clearance
Check the dyno between the 04/06
http://www.hondata.com/reflash_tsx_06.html
Check out my ride
http://www.cardomain.com/ride/2247067
Block improvements:
Other
Check out my ride
Mugen freak
damn, nice ride. how much did it cost to get the intake manifold polished, and where did you pick up your fuel rail from, and does that give any extra HP on the dyno?
Originally Posted by rabican
engine swap devalues the car allot...
Special-K
Originally Posted by UNEVAKNO
The manifold is powdercoated and I got a good deal. I got the fuel rail off Ebay. I have not put it on a dyno. But I will tell you what...with 19" rims I kept a 6spd G35 behind me and made him pull up to me at a light and ask did I have a turbo.So it hauls azz pretty good !!
Drives With Hands
^^ K100 is a CARB-legal plug-in flash chip progammed by Hondata (plugs in the ECU like a Kpro does) and is not programmable by the end user to make it CARB-exempt. So I have no idea how it is supposed to work in the TSX ECU since a Kpro won't.
What if they go to match the VIN on the engine block to any of the other ones on the car?
The car has not lost any value at all because the it looks just like the original motor and they will never know it came out. It was professionally installed by a certified Honda tech and I still have my full warranty until 50K. Hell the dealer installed my headers , clutch and my lightweight flywheel free under warranty.
Let me help you!
goddamn
So in actuality, it is about 15 hp improvement.
Originally Posted by UCF Accord
so you sold a motor with bent things for the same price you got yours for? i hope you told the guy and didn't give him the shaft
Thank you all for the props on my ride! No I didnt give the guy who bought my engine the shaft. I dont BS people! The guy who bought my motor works at the shop that did the engine job so he knows exactly what happened. I got such a good deal on the motor that the value was about even. The motor was not destroyed it still ran and got me home from the track. Honda makes a strong engine if it can still run after going from the top of 3rd gear into second which probably sent the rpms well past 10 grand.
As far as checking VIN numbers on the motor they would have me then thats if they really want to go that far. The value doesnt matter because I am keeping my car anyway.
Did I notice a difference you say? ..............Yes. When VTEC kicks in at 5 grand in 1st and sometimes in 2nd the stock tires break loose. I can now chirp 2nd hard and sometimes 3rd gear. It has that VTEC punch like a B18.
The fuel rail just improves fuel delivery, gives you options to upgrade injectors and looks good.
As far as where I live and the dealership ..................If I tell I will have to kill you.
Originally Posted by gamblez
so no hp gain with the fuel rail? and how did u get your car so light?
Originally Posted by rmpage
Damn, you removed your shock absorber?
what items did u remove from the car
dirtyspitshine
01-03-2023 08:23 PM
LECKEY73
02-22-2016 01:32 PM
justin7779
12-25-2015 10:33 PM
