Valentine One
Valentine One
anybody have the valentine one?
anyone hardwire it,
i think mine is comming with a kit to hardwire it, and i was wondering if there was a write up anywhere.
i guess i need to know the best place to run the wires, how to get the apillar cover off, etc etc.
thanks in advance.
anyone hardwire it,
thanks in advance.
There's a pic in this thread. Also some members noted how they did theirs.
http://www.acura-tsx.com/forums/show...ight=valentine
Here's a step by step writeup i found in the forum too.
https://acurazine.com/forums/audio-video-electronics-navigation-22/hard-wired-my-valentine-one-285547/
https://acurazine.com/forums/showthread.php?t=285547
I "hardwired" my V1 using a 12' telephone cord tucked into the headliner near the mirror, across above the passenger side sun visor (still tucked in the headliner), passed it under the side airbag assy (plenty of room), and down the b-pillar on the passenger side. Then I ran it across under the passenger seat, under the carpet 3/4 of the way (there are holes in the carpet to help you run the wire), then out of the carpet, under the inner seat rail, into the bottom of the center console, then plugged it into the power port inside using the cig lighter adapter.
I like this solution because I didn't have to cut any wires, and it turns on and off with the ignition. Also, when I sell the car down the road, I can pull the cord out easily, or just leave it in and only lose about $5.
The only parts that I removed to do this was the door-opening kick-plate (pop-in clips), rubber interior molding (just pulls out), and the plate surrounding the power port in the center console (phillips screw). The trickiest part was passing the wire under the center console (without removing it) and guiding it to the power port hole that was exposed by removing that screw.
The 12' wire was *just* enough to get there with about 1" to spare. If they had a 14' wire, I'd probably suggest that - but I think the next longest wire is like 25'.
I'm quite happy with the installation. I didn't have to remove the a-pillar panels, and it doesn't turn off when u put the car in reverse
Matt
Matt
Matt
Matt
i have the rj-11 connectons, with the crimper.
Originally Posted by 925tsx
well if i were to do that, id just make my own custom length of cord. i have the rj-11 connectons, with the crimper.
i plan on doing this mod this weekend, and i looked the diy thread, but im having problems figuring out which wire to splice the kit into.
how do i know which wire underneath the dash is a good one to splice into?
Fuse box is what im thinking as of now
https://acurazine.com/forums/audio-video-electronics-navigation-22/sirius-sat-radio-install-287187/
This was for a 2004 TSX, so you should double check the wiring when you do the install. Also, I noticed your question asking about how to get the a pillar off. Even though it sounds funny. I used a butter knife I used a really thin one and was able to get the SRS air bag clip without scratching or bending anything. Good luck!
yea i saw that thread...so i have to buy the add a circut?
the hardwire kit that comes with the detector has this quick splice thingy in it..so i dunno if i have to actually splice it to a wire or what
You can just cut off the connector on the hardwire kit and crimp the wire into the connector on the add a circuit. Or you could use the quick splice thing too, it doesn't really matter.
chrisr
12-04-2015 02:17 AM
