Trying to install oem kit
I tried to install my oem kit and i removed the black piece what else do i need to remove beside that in order to put the clips on them?? can someone help me out w/ the instructions? thanz
Installation Instructions can be found on www.honda_curaworld.com (remove the space between "honda" and "curaworld" )
1. Enter their online store and click on the Instructions tab (yellow tab near the top).
2. Select TSX and you will find the installation instructions.
Check out the instructions. My wife helped me on the install, so it is easier with 2 people. I am not sure what you are asking for help on exactly either.
The install is pretty straightforward on all the pieces. Good luck and again, read all of the instructions.
Originally Posted by tnl_tsx
for ex, when i tried to install the front lip, i had to remove the long black piece thing and is there anything else i need to remove in order to install? thanz for the tips
sides: replace original panels, original foam washers/squares, and wheel well sill
front: only need to remove the thin air dam/spoiler
cycdaniel
12-17-2019 10:58 AM
handsom-hustla
11-13-2015 05:04 PM
nuldabz
09-03-2015 05:49 PM
