splicing wires
Old May 12, 2006 | 11:32 AM
blacktsx05's Avatar
2011 M37x
splicing wires
when i installed my fogligts is it ok to splice the wires into the parking lights i was just wondering if that was safe. if not then i guess i'm just gonn have to do it the other way.
Old May 12, 2006 | 11:41 AM
jwhite4's Avatar
There's the obvious of making sure there's no chance of a bare wire getting exposed (and shorting to ground), and that it is protected from water infiltration, You would want to make sure whatever type of connection you used is rated for the amount of current the foglights will be drawing. Also, check the fuse rating on the parking light circuit. Foglights I'd expect will draw a lot more current than parking lights, and you wouldn't want your fog light use to blow the fuse and take out your parking lights.
These are just general suggestions, others might know more TSX specifics.
Jeff
Old May 12, 2006 | 12:02 PM
blacktsx05's Avatar
2011 M37x
ok thanks
Old May 12, 2006 | 12:08 PM
San-AnT's Avatar
The Power of a Grill
i thought you got the OEM fogs....no cutting of wires needed for that
Old May 12, 2006 | 12:15 PM
moda_way's Avatar
Originally Posted by blacktsx05
ok thanks
No, they are different wattages. The fogs are 55W and the parking lights are lesser I believe. Also, direct wiring into that line can be dangerous if the switch fails. In the OEM configuration, they use a relay to bridge the electricity vs what you want to do is use the switch. Not saying you can't do what you want with this, but it isn't the safest method.
Old May 12, 2006 | 12:17 PM
moda_way's Avatar
He's trying to get them to turn on with the parking lights rather than with the headlights.
Old May 12, 2006 | 01:07 PM
S14 n Tsx's Avatar
mmmmmm....
Its going to require alot of work...I think?
Old May 12, 2006 | 01:52 PM
blacktsx05's Avatar
2011 M37x
ok thank guys i'm guess i'm just gonna have to stick with the ways it usualy works then.
Old May 12, 2006 | 02:35 PM
moda_way's Avatar
Short of adding in your own relay, switch and such, the normal install is the safest and most reliable way.
Old May 12, 2006 | 02:38 PM
blacktsx05's Avatar
2011 M37x
yea i need a reliable car. its not a 94 integra where you can do anything to it.
Old May 13, 2006 | 12:10 AM
San-AnT's Avatar
give it a shot anyway, if it works i will follow your lead . if it doesn't, then thanks for the warning.
Old May 14, 2006 | 12:34 AM
S14 n Tsx's Avatar
mmmmmm....
what a dick!! jk
Old May 14, 2006 | 12:40 AM
blacktsx05's Avatar
2011 M37x
nah i'm aint gonna try that i dont wanna mess anything up. but im intrested to see what would happen if i would do that.
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
