Should Water Pump be replaced
Old Jun 12, 2019 | 10:56 PM
hitesthonda's Avatar
Hi: I have a 2004 TSX with 53k miles. Should I replace the water pump proactively just to be on the safe side?
Old Jun 13, 2019 | 09:25 AM
TexasHonda's Avatar
No, wait for bearng noise or leak. Too much potential for making a problem.'
good luck
Old Jun 14, 2019 | 07:24 PM
Thanks! Appreciate that! Won't do it.
But, just curious, and if you don't mind; What kind of problems could replacing the WP cause?
Old Jun 15, 2019 | 10:51 AM
TexasHonda's Avatar
Leak leading to overheating is big risk. Broken bolts due to overtorquing (small bolts require < 10 ft - lbs).
Primary reason is that failure is not catastrophic (such as timing belt).
good luck
Old Jun 15, 2019 | 10:57 AM
agreed, first timers or inexperienced mechanics will mess up things...however; skilled mechanics can replace things without breaking stuff. lol
a lot of times, people(unskilled mechanics) will break things and not tell you, until next time you go to change it out and find they absolutely FUBAR'd it and took a backyard approach to fix it; ie; not replacing it with a new part. either to save money, or didnt want to tell you, the customer.
Old Jun 15, 2019 | 01:24 PM
Thanks ALL!
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
imakeholesinu
Dec 30, 2012 09:08 PM
Nick Tiger
Dec 3, 2011 07:49 AM
StonedCL
Sep 3, 2009 06:46 PM
civic4982
Nov 18, 2003 12:41 PM
