No Vtec
Old Mar 17, 2004 | 01:42 AM
teddy's Avatar
No Vtec
hi i just installed the injen cold intake in my tsx AT with 500miles,after that i go to a test drive and i hit to 7000rpm, the intake is very loud but i cannot hear the vtec kick in sound ,so is that is my car problem or it is auto,because before i test drive the honda pilot, accord v6,si and rsx ,when they hit around 5000rpm it will change sound ,so what happen with tsx ,can somebody can told me
Old Mar 17, 2004 | 02:43 AM
Lung Fu Mo Shi's Avatar
Registered AssHat
You should hear it around 6000 rpm (and feel it).
Old Mar 17, 2004 | 03:19 AM
EURO_R's Avatar
Fellow Designer!!
did u reset the computer after u installed it??, yes it is plug and play but u also have to disconnect your battery and reset the ecu!!
Old Mar 17, 2004 | 03:31 AM
N_Smith's Avatar
UMM... was the engine cold on your test drive?
-nick
Old Mar 17, 2004 | 12:55 PM
teddy's Avatar
do u guys think is a auto or manual problem
Old Mar 17, 2004 | 01:00 PM
CGTSX2004's Avatar
Nope, definitely not. I have the automatic and when the i-VTEC kicks in, you can definitely hear it. It's closer to 6000 rpms than 5k.
Old Mar 17, 2004 | 05:14 PM
xizor's Avatar
Bye TSX, hello domestic?
mine sounds like a wild animal after 6200rpm
I wouldn't worry so much about the sound, can you feel it? Try getting up to Vtec w/o stomping on the throttle. The intake should make no extra noise and you should easily be able to hear the engine.
Old Mar 17, 2004 | 06:35 PM
tony4311's Avatar
I am Ahab!
good point. Are you at WOT when doing this. It's pretty short time to listen compared to the rest.
I still don't think yo really need to hear it
Old Mar 17, 2004 | 06:36 PM
ecsw's Avatar
I can not hear Vtec from my AT either, but I can feel it for sure.
Old Mar 17, 2004 | 08:46 PM
LaxTSX's Avatar
regarding reseting the ECU?
Do you really have to reset the ECU? This is the first time I've heard of this, so does anyone know if its needed? If it is, then I need to go and reset that bad boy!
Old Mar 17, 2004 | 08:52 PM
Ayumi's Avatar
vtec sound
i have an injen intake, you can hear and feel it @ 6000rpm, and mine is AT. maybe your car is still too new.?
Old Mar 17, 2004 | 09:00 PM
teddy's Avatar
oh thanks for everybody to help,finally i can hear the vtec kick in sound on about 6000rpm ,may be the first time the car is still cold,thanks
Old Mar 17, 2004 | 09:29 PM
JTso's Avatar
Absolutely NOT! Resetting the ECU erases stored codes and STFT/LTFT info but it has nothing to do with the problem.
Old Mar 18, 2004 | 02:00 AM
LOL888's Avatar
do you guys with autos feel any difference in performance? I mean I don't know if it'd be worth it to mod an automatic
Old Mar 19, 2004 | 02:16 PM
DaiLo77's Avatar
From my old racing days, It is beast to reset the ECU when something in installed in your ride (performance wise) so the Ecu will read it. Just a simple battery disconnection will do it.
Old Mar 20, 2004 | 03:56 AM
masmole's Avatar
Uh, I know you can hear it (if you really listen) but what is this "and feel it" thing you talk about? lol! I certainly don't feel it. You make it sound like there's a huge influx of mass-motivating torque that comes from the motor at 6K.... in reality, TSX's torque curve drops at around that engine speed and the cam profiles go long just to squeeze out whatever power the screaming 4-banger has left over to make the final stretch to 7K. VTEC certainly kicks in, but seems that in this application, Honda has tuned it so that it kicks in smoothly at the most approprtiate time and without drama so that even the most sensitive of butt dynos won't feel it because it simply isn't there.
VTEC in the TSX is very unlike VTEC of past Hondas like the si's, prelude, etc. It's a more civilized, smoother, and liveable evolution of VTEC. At 6K and above, there's really nothing more to feel, but I won't deny that it's still sweet music to my ears.
Old Mar 20, 2004 | 08:46 PM
Ayumi's Avatar
vtec @ 6000rpm
vtec@ 6000rpm, you should feel a little twitch. Nothing huge, and a sound change thats about it.
So for sure there is a tiny kick in there which almost feels nothing.
IBankMouse
Jun 13, 2020 12:53 PM
Dunnik
Sep 15, 2015 11:52 PM
Tsov Tom
Sep 6, 2015 07:56 AM
Desert Ridge
Sep 5, 2015 09:47 AM
LAMike240
Sep 3, 2015 04:35 PM
