Modify your navigation system
Old Jun 10, 2008 | 05:39 PM
  #1481
jim13's Avatar
yes i have a DVD burner and all that stuff but nothing happening
Old Jun 10, 2008 | 09:46 PM
  #1482
jim13's Avatar
I got it, Does anyone know how to remove the OK button when you start the car.
like
That OK button gets annoying if anyone knows how to remove it please tell me Thanks
Old Jun 10, 2008 | 11:34 PM
  #1483
tisguy409's Avatar
angrydad has a patch to get rid of the ok button but it only works on the orange discs. As far as I know nobody has gotten it to work with the white disc.
Which disc do you have?
Old Jun 11, 2008 | 07:17 AM
  #1484
kfc469's Avatar
like
man its a good thing you took some time to look through this thread before posting. the answer is no, at least if you have the 4.xx version of the dvd. what you can do however is change the startup pic and change the text in the disclaimer. see the link in my post above
Old Jun 13, 2008 | 04:11 PM
  #1485
jim13's Avatar
Navi Screenn got mess up, When ever star starts the splash page shows and keep showing. i can't get into the Menu/setup/cancle place. is there any other way i can resete without d/cing the battery? If i d/c the battery would i have to enter in the radio/navi code again?
Old Jun 13, 2008 | 07:24 PM
  #1486
tisguy409's Avatar
Is it on an infinite loop? it happened to me, but the set up/menu/cancel trick worked for me...
Old Jun 13, 2008 | 07:29 PM
  #1487
jim13's Avatar
yea an infinite loop, but when i keep holding down set up/menu/ cancel the screen menu never pops up any help?
Old Jun 14, 2008 | 02:09 AM
  #1488
tisguy409's Avatar
i remember pushing it when the splash screen was up... you could try to go into the diagnostics menu by holding menu, map, and set up. then from there go into the setup/menu/cancel to get into nav diagnostic screen. thats how i fixed mine
Old Jun 14, 2008 | 09:17 AM
  #1489
jim13's Avatar
so you have to press it 2 different times?
Old Jun 14, 2008 | 09:27 AM
  #1490
jim13's Avatar
the setup/cancle is on same button how can you press that? and i just tryed didn't work
Old Jun 14, 2008 | 10:51 AM
  #1491
tisguy409's Avatar
they're seperate buttons. they look like they're one piece, but one toggles right and the other left. If the keyed in doesn't work, you might just have to disconnect the battery.
I was assuming your navi looked like this:
Old Jun 14, 2008 | 11:20 AM
  #1492
jim13's Avatar
yes it look like that but when u said hold Menu Setup and Cancel how would that work if its one piece?
Old Jun 14, 2008 | 12:18 PM
  #1493
tisguy409's Avatar
wait, maybe it was map+menu+setup. I was randomly pushing 3 button combinations when i got into that screen. It's been a couple weeks since I tinkered with it.
Map+menu+cancel= navi config menu
map+menu+set up= diagnostics
Old Jun 14, 2008 | 12:54 PM
  #1494
jim13's Avatar
well thanks for helping but my brother just pullied out the battery so everything is all good now.
Old Sep 20, 2008 | 11:02 AM
  #1495
spyke's Avatar
Has anyone successfully replaced the DVD drive with a USB Flash based drive? The advantages would be numerous. Faster access time, no moving parts, no fragile disk to scratch, more easily modified, much less space. I'm not sure of all the technical hurdles that would be involved, but with an 8GB flash drive it sure seems a better way to go. Simply copy all the files from your current Navi DVD to the flash drive, plug it in, and away you go. Other than physical connections, does anyone know how to make a flash drive appear to the system as a DVD? Any suggestions on hardware? I have yet to pull the DVD drive out, perhaps the connections are too complex to simply swap out the drive.
Old Sep 23, 2008 | 08:13 PM
  #1496
DavidIQ's Avatar
There's no hardware on the actual unit to do that. So the answer is...NO
Old Oct 19, 2008 | 05:40 AM
  #1497
Peng0's Avatar
~radiowave~
I have Honda Accord Navi disc ver. 3.04 APN2-46102 Europe. How can I change the background picture to my own image? Model of car Honda Accord '07 CL7.
Old Apr 4, 2009 | 10:21 AM
  #1498
thedreamer's Avatar
I need a map for accord 2006 navi sys
I bought accord 2006 4 cylinders 4d with navigation system from US , I use it now in middle east but I can’t see maps so I bought pc card with 2GB SD memory card to install the new map in it. I want to know which file type my unit can read of if I can put a map from GARMIN, TOMTOM, MAJILAN or others
or if i can modify my DVD
advice me
Old Apr 11, 2009 | 01:32 AM
  #1499
nimo_253's Avatar
Updated Navi problem
I DLed a 2008 navi program from the TL. I used a dual layer DVD to burn the program, installed in my 06' TSX just fine and when I start the car it says that it can't read the DVD. I tried going back to the original but says that it was an older version and gotta take it back to the dealership. I'm going to try the method mentioned by dysin. BBL.
BTW anyone know what the flash slot is for, other than data? Mp3s? Mpegs?
Old Apr 19, 2009 | 11:27 PM
  #1500
ant2112's Avatar
I have a '06 tsx and from looking at the instructions i may be able to do this. Before i attempt, has anyone made a video how to do this step by step on the computer.
thanks.
Old May 25, 2009 | 09:32 AM
  #1501
thedreamer's Avatar
advice me
any idea
Old May 25, 2009 | 10:56 AM
  #1502
SoCaliTrojan's Avatar
Let me help you!
advice me
The pc card slot in the navigation drive is not for maps. It's for the manufacturer's use only so they can pull diagnostics off of it or something like that.
What you probably will need to do is make a car pc. The pc will sit in the trunk, and display its output on the navigation screen. Since the open source group hasn't finished hacking the navi's touch screen, though, you'll probably need a wireless/bluetooth keyboard to send commands to the pc. I don't know of any navigation software that runs on a car pc, but maybe there is a solution out there. (I've seen car pc's installed in our cars, but I don't know the exact technical specs on them).
Old May 26, 2009 | 10:03 PM
  #1503
tuoncan's Avatar
http://www.youtube.com/watch?v=As9dnf9viE0
Old May 28, 2009 | 10:44 AM
  #1504
Originally Posted by bysin
I didnt include the navi-nonag.exe or any other modified files with the zip because its copyrighted by Acura. All files that you wish to update you'd have to modify yourself. But I'm sure anyone with a SH-4 disassembler and a hexeditor can figure it out how to remove the nag screen. I'll give you all a hint, 0x0900 is nop.
I think I have this laying around somewhere, I think its with my
flux-capactior...........
Old Jun 22, 2009 | 04:40 PM
  #1505
SirataXero's Avatar
8th Gear
Originally Posted by tuoncan
zOMG WTF?!?!?!
REALLY?
Old Jun 24, 2009 | 12:49 PM
  #1506
thedreamer's Avatar
thanks for for the idea but i can't do it
Old Jun 24, 2009 | 12:59 PM
  #1507
thedreamer's Avatar
advice me
any other idea
Old Jun 28, 2009 | 09:57 PM
  #1508
cybereclipse's Avatar
私はより良い
any other idea
its just not possible
unless alpine ( the company acura/honda contracts to make the dvd navigation systems) sells DVDs with middle eastern maps, you're SOL
Old Jun 29, 2009 | 03:28 PM
  #1509
thedreamer's Avatar
no way to hack the dvd and add the map imag
Old Jul 16, 2009 | 04:58 PM
  #1510
Hypercooldude's Avatar
What I was planning on doing was writing my own and offering it as a replacement for the stock navigation system in all Honda/Acuras. It'll be more graphical and more customizable then the stock system. I'd use the PCICMA card slot for extra storage, or for 802.11g access in your car.. The problem people are having now with 802.11 cards in their PCMCIA slot, is that the software prevents you from having your drive bay open. So, obviously, replaceing the software completely would solve that problem.
Bysin.
Having the experience in SH-4, i wanted to know if u could reply to a few simple questions.
I have imported a Honda Accord from japan.. wich is basically the Acura TSX .
I has everything in japanese. I tried loading the american orange DVD and it didn't install it.
When i compare the two dvds in my laptop, the japanese one has .DAT files and there is no .BIN file at all.
Still when i access the version screen, it shows a specific .bin file being used by it.
I don't understand where the .BIN files are. And i would greatly appreciate it if you cud give me a heads up on how to install the american navi disc onto it.
If u need the japanese navi disc, i can upload it for u to examine. Or i cud send u a select few files from it (which wud be much easier due to smaller file sizes)
Dude, help me out here.
Oh and one more thing. Here is a tip for EVERYONE who wants to make a backup of their DVD.
Burn ur DVD+R DL in DVD-ROM Booktype. It works like a charm.
How you do it. Well , just download the latest Nero in trial version. Install it. Goto Nero DiscSpeed. In 'Extra' click 'BitSetting'. in Bitsetting, next to DVD+R DL select DVD-ROM and Click the SET button. You are done. Now write the image of ur original dvd as a Data DVD (no multisession). Pay attention to the log messages when the Burn is in progress. It will say : Booktype Set to DVD-ROM. If u hav reached this point, u will burn a disc that shall work on ur Acura / Honda
On some drives, the BitSettings are Greyed out. Tough Luck. If u have a LiteOn, BenQ, NuTech, Samsung, NEC, LG, Plextor or Ricoh drive, ur in luck cuz then instead of Nero, Download IMGBURN. That software supports all those drives when Nero doesn't. Just Click Tools, Drive, Change Booktype.
Anyways....
Hey Bysin ... help me out dude.. it sucks not being able to use ur Navi system. Not even the Bluetooth system.
Old Jul 19, 2009 | 12:58 AM
  #1511
hkppl111's Avatar
sorry, im just too tired to read all posts in this thread.
i knew sth about changing the nag screen, but i dont know how to change the word on the "ok" sreen.
can anyone tell me how to do it? or tell me the page in this thread that explain how to do it? plz
Old Jul 20, 2009 | 11:43 AM
  #1512
kingkong222's Avatar
at least it's not like the Lexus's nav system where you cannot do anything while driving. Can't look up restaurants, can't change the destination point unless you stop the car completely. How lame?
Old Aug 20, 2009 | 06:14 PM
  #1513
renan's Avatar
6th Gear
Registered User
Trader Rating: (0)
Posts: 127 Modify your navigation system
I've developed a program to modify the navigation system in Acura/Hondas.
The actual navigation system is in Windows CE running a SH-4 processor, similar to a Sega Dreamcast (if not identical). I just bought my TSX about 2 days ago, but luckily I had a lot of experience hacking the Dreamcast so it didnt take me very long to hack the navigation system.
Here is the link to the program including there Visual C++ source code:
http://www.linuxkiddies.com/bysin/navi.zip
bysin/anyone,
url is closed already. can anyone tell me where to find this program...thanks in advance
Old Sep 2, 2009 | 03:03 PM
  #1514
hubtech's Avatar
Try this one instead: http://www.linuxkiddies.com/bysin/navi
Old Sep 2, 2009 | 04:23 PM
  #1515
millsjq's Avatar
5th Gear
Do you have the navi-nonag.exe available for those of us that want to take advantage of your work.
Jack
Old Sep 19, 2009 | 04:19 PM
  #1516
Extremistpullup's Avatar
Jack
same here
TLPatch401a.com - AngryDad's trip computer patch.
HMIManager.zip - Kenny's modified trip computer for v3.40c (password: kennyc)
NaviOK401a.com - AD's OK button patch for Navi 3.50
navi.zip - Kenny's modified OK executable for Navi 3.40c (password: kennyc)
These links no longer work
are there new links?
Old Sep 19, 2009 | 04:27 PM
  #1517
DavidIQ's Avatar
Originally Posted by Extremistpullup
same here
You didn't actually try clicking through on any of those did you? Clicking on the first and third links eventually ends up at:
http://www.vistabug.com/bb/viewforum.php?id=2
Old Oct 5, 2009 | 09:24 PM
  #1518
TRU3 L3GEND's Avatar
If anyone still has Kenny C's navi.zip and modified trip comp for the 3.40c disk please re upload it, I have been looking for months now. thx
Old Mar 30, 2010 | 11:55 PM
  #1519
illmaticskillz's Avatar
Meee 2!
Old Mar 31, 2010 | 12:30 AM
  #1520
Originally Posted by illmaticskillz
Meee 2!
Here is everything you need
http://rapidshare.com/files/37020270..._pack.rar.html
