climate control question
Old Nov 3, 2003 | 08:22 AM
spc's Avatar
spc
Hope this is not being asked or a FAQ.
Does anyone know whether the auto climate control also control the humidity inside the car? Or it just control the temperature?
The reason I asked because it feel much more comfortable than my old 1992 vehicle without auto climate control.
Thanks!
Old Nov 3, 2003 | 09:04 AM
gogozy's Avatar
i don't know but acc will keep a/c on all the time, this will remove moist in the air.
Old Nov 3, 2003 | 09:16 AM
DEVO's Avatar
yeah it's pretty lame... the a/c is always on. there is a procedure that you can override the a/c when defrosting but I don't know the sequence for the TSX. There are links to the sequence to override the a/c for a civic (doesn't work for civic hybrid which sucks). I'm sure somebody here will know the sequence to allow for the a/c to be overriden. I think I started a link on this site about this... if not it's on another TSX board.
Old Nov 3, 2003 | 09:20 AM
esr5096's Avatar
The A/C is on all the time if your defroster is on, but just using climate control I think it goes on and off. Don't know if the climate control measures humidity, my guess would be just temperature.
Old Nov 3, 2003 | 09:47 AM
gogozy's Avatar
i can hear the compressor's noise even when i set the temp to hi in cold cold morning cold start. this is a bad design, i want a/c off when i am warming up the car... i am thinking of putting a switch on the a/c fuse so i can switch it on and off but don't know if this will cause other problem. but remember running a/c at least once a month to lubricate the compressor.
Old Nov 3, 2003 | 09:52 AM
esr5096's Avatar
Why add a switch? Why not just hit the "A/C" button that switches it on/off rather than leaving it in auto mode? Even though the car has climate control, you still have full control to turn anything on/off if you want to override it. Seems silly to add a switch to do the same thing as the button right there on the controls!
Old Nov 3, 2003 | 10:06 AM
gogozy's Avatar
whenever i start the acc, the a/c kick in, then i need to turn a/c off, if i don't want a/c then i need to left it on all the time, it is blowing cold air in sub-0 temp when i am starting/warming the car, and it cause more wear
i recall a/c start after car are fully warm up is a better idea.
Old Nov 3, 2003 | 10:20 AM
esr5096's Avatar
That's odd, my climate control doesn't start blowing air in the cold until it's warm. Do you have your defoster on? If so, that's why, if not, sounds like you should have the dealer check it out.
Old Nov 3, 2003 | 11:59 AM
DEVO's Avatar
I think the confusion here is that there is no way of getting rid of the A/C when you are using the defroster. I think this is a poor design... especially in the winter month where the air is dry and cold... just heat will do fine. No need for a/c to be on under these conditions which is pretty much all of winter... (not talking about snowy or wet conditions here).
Old Nov 3, 2003 | 02:00 PM
XPLORx4's Avatar
My other "car" is a 4x4
The only way to have the AC not run when air is directed towards the windshield is too run the system in "mix" mode, with air going to the defrost vents and to the floor.
Old Nov 3, 2003 | 02:52 PM
DEVO's Avatar
hmm... i'll have to try that on my civic.
Old Nov 3, 2003 | 04:04 PM
Dan Martin's Avatar
Photography Nerd
I can't believe how fast the front defogger works. It's litterally 5-10 seconds before the window is clear.
Old Nov 3, 2003 | 04:58 PM
ssm_tsx's Avatar
It's not the same for my TSX. I can shut off the a/c just by hitting the a/c button when the car is in defrost mode.
Old Nov 3, 2003 | 05:07 PM
Lung Fu Mo Shi's Avatar
Registered AssHat
Exactly. Sometimes I'll put the air up on top (front window vent) and turn off the A/C. By "Default" the A/C turns on, but I just push the A/C button and it turns off.
Old Nov 4, 2003 | 08:39 AM
DEVO's Avatar
ok that good to hear... in my civic, i can't turn off the a/c in defrost mode.... or mix defrost mode.
in wet weather this is fine but in cold dry days... this sucks.
Dec 7, 2020 05:39 PM
Rachel Lu
Sep 27, 2015 09:53 AM
Rob144
Sep 21, 2015 08:18 AM
lovic87
Sep 15, 2015 06:07 PM
PortlandRL
Sep 14, 2015 12:01 PM
