Any TSXers install a 5-6 point racing harness in their ride?
Originally Posted by GTSX-05
You should see how hard I push it through a corner!! but I agree, it would mainly bee for aesthetics
I am Ahab!
Originally Posted by DiaBando
I've always thought it would be a good, safety add-on.
If you don't have a cage then it would NOT be a good add on.
If you roll over in a regular belt you can survive because your body gets pushed down and not crushed. With a harness your body goes nowhere and the roof crushes you.
Originally Posted by visuelz
I heard that the harness is dangerous, if you're not sitting correctly. And if you do sit correctly, you're not really going to see your mirrors.
More than likely, though, your overall seating setup is not correct for a 5-point harness anyway. You have to do this stuff right, which includes drilling holes at proper angles and measuring dimensions for the driver. Most likely you'll have to fabricate brackets, etc. to get it right.
Harnesses can be dangerous for a couple reasons.
One, you can't get out of the way if something is going to come through the windshield (you would be surprised at just how often this happens). Two, I see accidents all the time where car's flip over and the roof is crushed in, with a harness (and no cage) you would be crushed as well. Three, if you don't get a sternum protector you can very easily seriously injure yourself because most harnesses only come with two straps that go on each side. In the event of a serious impact, your chest is going to keep moving in-between those straps. And also if you have the belts mounted at too much of an angle, in an accident it'll compress your spine.
Originally Posted by Populuxe
This is generally a silly sentiment. Vehicle cabins are designed to prevent cabin intrusion upon rollover and your chances of crushing the roof in, cage or not, should be the least of your worries when dealing with a harness.
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
11-13-2018 04:44 PM
Skirmich
09-15-2015 06:41 PM
IndycarFaster
09-11-2015 02:52 PM
Gianni Formica
09-07-2015 08:28 PM
