Antifreeze/coolant
Antifreeze/coolant
A few days ago while I was checking the engine oil level, I noticed antifreeze/coolant level was at MIN. I don't think it's leaking as I don't have any traces of antifreeze on my driveway. I topped it up today with Prestone (50:50 premixed). Is it normal to fill up antifreeze once in a while? Did any of you had to fill up antifreeze on your TSX?
ok well here's my dilemma...mine would be way below the min level and i have filled it up twice in the last month or so... i know that i'm here in jax and its soooooooooo hot ..but i dont think that a car needs that much antifreeze in 2 months??
When I first got my TSX I had the same problem. Then I noticed what appeared to be traces of coolant in the threads of the reservoir tank cap. I removed it, cleaned up the threads and made sure the cap was on tight (it felt less that tight when I unscrewed it) I never had the problem again. It may be worth checking
Theres been reports of this same problem, on the TL forum regarding some coolant loss in these cars. Doesn't seem to be an internal leaks, just some evaporation.
An oil analysis would be the best way to check for any leaks, yes I have seen an 04 TSX leak coolant internally.
Prestone All Makes/Models or the 50:50 premixed version is fine, though I'd flush out the entire cooling system before adding it in.
This is because I have another car in the family, a 96 Saturn that specs silicated green coolant. Last mechanic who did a flush with Prestone Extended Life Dex-Cool, didn't flush out the system completely. Thus, that may have possibly caused the buildup around the filler neck area.
However, the Dex-Cool is perfectly pink.
MW
However, the Dex-Cool is perfectly pink.MW
ska325xi
1G RDX (2007-2012)
Jul 31, 2009 05:30 PM
