2006 TSX Info...
Old 09-18-2005, 12:30 PM
  #761
TSX4EVR
excited's Avatar
Originally Posted by J J
Any new pics of the car out yet?
Enjoy!! http://www.vtec.net/news/news-item?news_item_id=398963
I still look at this site and the pics several times each day. I can't wait until December.
Excited
Old 09-18-2005, 04:33 PM
  #762
Top notch 6MT
05_TSX_GP's Avatar
Originally Posted by xizor
LSD and VSA work in opposite ways to do a similar function. An LSD helps you go faster by making better use of your engine power, VSA slows you down reducing power. IMO a LSD is for performance, VSA is for safety. My wife's MINI has both a LSD and DSA (dynamic stability assist) and the LSD is a blast when cornering. Don't let those articles fool you about a LSD being regular "traction control", its really for better cornering.
Old 09-19-2005, 11:31 AM
  #763
Bill Hook's Avatar
Originally Posted by STL
Also note that the TL also has almost 1" larger rear rotors as well. My S2000 (weighing in about 450 lbs. less than a TSX) has the same sized front rotors but here again actually has the 1" larger rear rotors. I fully admit this compliant is based off what others here had said AND the fact the TSX doesn't seem to do all that well in the braking test I've seen in the mags (but I guess that could be partly the tires).
The 2003 RSX-S A-spec shaved about 20 feet off its braking distance from standard w/ better summer tires and higher friction pads (as per Car & Driver). The last test of the 2005 RSX-S w/ better tires showed about a 15 foot improvement, now with larger 17" A/S tires as OEM equipment (as per C&D). I think there's a pattern here and believe a change of tires and pads could net something similar to this for the TSX.
Old 09-19-2005, 12:33 PM
  #764
acn684's Avatar
Wheres the MP3 jack?
Description says that the Aux input is in the center console....anybody see it?
Old 09-19-2005, 01:33 PM
  #765
My Garage
GIBSON6594's Avatar
its probably inside the the center console
Old 09-19-2005, 10:45 PM
  #766
J J
J J's Avatar
Excited
Whoops, sorry, I mean are there any brand new pics out there...thanks though!
Old 09-19-2005, 11:03 PM
  #767
Former Audio Mod
schalliol's Avatar
Holy crap, the lower front bumper is ugly.
Old 09-22-2005, 11:52 PM
  #768
J J
J J's Avatar
Will there be a more significant styling change on the 2007 or 2008 TSX? the changes on th 2006 are so minor. Thanks
Old 09-23-2005, 12:03 AM
  #769
Mmm.. Acura cake
Gary757's Avatar
Doubt it. Since the 2006 TSX represents the mid-cycle model, changes for the 2007/08 will likely be *less* significant than changes on the '06. i'm speculating that the most noticable change in 2007 could be an introduction of LED taillights to bring it up to speed w/ the LED-equipped 2006 Accords beneath it and the already LED-equipped TLs above it.
Old 09-23-2005, 12:25 AM
  #770
I'm a llama :(
Motohip's Avatar
Well in 2008 it'll be redesigned.
Old 09-23-2005, 12:01 PM
  #771
J J
J J's Avatar
Ok, I may get the 2006, then sell/trade into the 2008 when it comes out if it is improved.
Old 09-23-2005, 02:22 PM
  #772
C'mon, man! Row yer own.
peter_bigblock's Avatar
I wonder how much add'l weight the '06 gains by adding more cool stuff, stiffening, sound-deadening, whatever. (It just seems like, with each redesign, cars gain weight as they gain cool stuff.) Enough to offset the 5-10 hp gain? The stock '04 is about 16 lbs/hp, meaning if the '06 is 160 lbs heavier then the seat-of-the-pants will be about the same I think.
I plan on driving my 04 TSX until it won't go anymore -- I like the car that much. Each subsequent model will be cooler/faster/better, I suppose, but I like everything about my car (including the XM Roady 2 I bought for $50 and can also take on the boat or in the house, as opposed to the hard-wired version '05 forward) and will really like the $450/mo I won't have to spend in a couple years.
So I'm getting Hondata-fied, do the i/h/e, replace the Michelins, and love my TSX ten more years.
Old 09-23-2005, 02:34 PM
  #773
dom
dom's Avatar
I could be wrong but I don't recall reading that it was stiffened or received extra sound-deadening.
Old 09-23-2005, 07:08 PM
  #774
J J
J J's Avatar
The windshields are specially designed to reduce wind noise...
Old 09-24-2005, 01:44 AM
  #775
First US '06 TSX on board
markcoburn's Avatar
thought it was just new wipers
Old 09-24-2005, 10:54 AM
  #776
J J
J J's Avatar
"Flat wiper blades increase visibility and reduce wind noise"
http://www.hondanews.com/CatID3039?m...72495&mime=asc
Old 09-24-2005, 04:55 PM
  #777
Top notch 6MT
05_TSX_GP's Avatar
Wonder if that can be fitted to my '05
Old 09-24-2005, 07:27 PM
  #778
markcoburn's Avatar
The point is, I don't think the wipers added any weight to offset the HP increase. Unlike a specially designed windshield, stiffening, and sound-deadening might.
I wonder how much add'l weight the '06 gains by adding more cool stuff, stiffening, sound-deadening, whatever. ...Enough to offset the 5-10 hp gain? The stock '04 is about 16 lbs/hp, meaning if the '06 is 160 lbs heavier then the seat-of-the-pants will be about the same I think...
Old 09-24-2005, 10:07 PM
  #779
I was mainly just wondering -- I don't know that the '06 is any heavier or, for that matter, any lighter than the '04/'05. I'll be interested to see the specs when they come out.
Old 09-28-2005, 08:31 AM
  #780
J J
J J's Avatar
Is there any word on the 2006 TSX being posted on the Acura Web Site?
Is there any word as to when the car will be released to dealers in the USA?
Thank you.
Old 09-28-2005, 11:18 AM
  #781
Pink as a pistol
Hondan53's Avatar
Thank you.
I ordered my 06 TSX AT w/ NAVI last weekend. My dealer is not sure when all of the info will be released, but they think the official info will be released around end of November, and my car should arrive around December, possiblly but not likely, January.
Old 09-28-2005, 04:22 PM
  #782
J J
J J's Avatar
Wow, so you ordered already, did they go over the options with you?
Were there any Rim Options or Body Kit options? Thanks.
Old 09-28-2005, 08:50 PM
  #783
3rd Gear
LAURASCAR's Avatar
I called acura. They said the car would be in dealers showroom by november 6
Old 09-28-2005, 09:23 PM
  #784
Mokos23's Avatar
wow laura, are you sure you can reach the gas pedal cause you're only 4, :P.
Old 09-28-2005, 09:54 PM
  #785
TSX4EVR
excited's Avatar
I don't think that the dealers know anything more about the 2006 than us and I think a lot know less. Acura has not released a lot of information to them yet.
For my purchase of the 06 TSX we based the price on the existing TSX added normal 05 options and came to a price. They didn't know any details.
Excited
Old 09-28-2005, 11:35 PM
  #786
feliz's Avatar
When I orderd my 06 I just went for $1,500 under MSRP whatever that will be.
Old 09-29-2005, 12:12 PM
  #787
Only Acuras Since '93
Irfo's Avatar
Thank you.
My dealer says the '06 I ordered a month ago will be in his first shipment, and he expects it in mid-November. He can't tell me a thing about when MSRPs and the accessory list will be out (he tells me he won't have the '06 accessories themselves in stock until a month after the cars start arriving!), but this convinces me it will be at about the same time, so I expect the web site update won't happen for a month.
He also confirmed that the MSRP increase will be no more than $200, but he said the delivery charge is going up by $110, for obvious reasons.
Old 10-23-2005, 11:54 PM
  #788
J J
J J's Avatar
Any news on this car for the release data in USA dealers or release date of info on the Web Site, or new pics?
Old 10-24-2005, 08:40 AM
  #789
PWP Wh0r3
RTSX-ASpec's Avatar
one dealer told me the new one will arrive in december, god knows when in december and that's in Canada. I would assume somewhere around that for US?
Old 10-24-2005, 02:19 PM
  #790
Got Ramen?
TypeRS's Avatar
November 9th seems to be the official release date for the 06 TSX, pricing wise, and when the model will show up on the Acura website. The car should be out for sale around that date...
Old 10-24-2005, 02:33 PM
  #791
asethi16's Avatar
yup u are right typeRS..... ic alled up Acura Customer Service and they said all info will be out Nov 9th. Cant wait to see what happends. They are even sending me a brocure since I'm too lazy to get it from the dealer.
Old 10-24-2005, 04:23 PM
  #792
kyotousa's Avatar
you are awesome
at first i thought 06 will look gay
but it should look good...............so lucky :P
just change the wheel thx haha
Old 10-24-2005, 04:33 PM
  #793
STL
STL's Avatar
The delivery charges already went up by $100+ about two months ago -- so are you saying they're raising it again?
Old 10-24-2005, 06:03 PM
  #794
hans007's Avatar
no it wont.
the 08 models will be like the current one and probably come out in the fall of 2007, the '09 models which would come out in spring 2008 would be the new ones.
i also went to my acura dealer to get something serviced today. they are still taking delivery of 2005 model cars into november.
in fact they had a brand new white one there today (which they didnt have last week when i bought my car)
Old 10-24-2005, 07:03 PM
  #795
Irfo's Avatar
Hmmm.... well, that post was from Sept. 29, after a recent call to the dealer-man, and as of early August when they wouldn't come down enough to make an '05 worth it to me, the destination charge in NH was USD $570, so I interpreted it to mean an increase to $680.
Butthinking about it, it's entirely possible that two increases are occurring and I only know of one, so that's about all I can tell you. Maybe I'll hear a new number when I call the dealer-man on the morning of the 9th and make him my offer.
Old 10-25-2005, 07:47 AM
  #796
storwatch89's Avatar
The dest charge for 2005 RL is 570 and 2006 RL is 615 from acura.com website. It increased 45 dollars. Where do you get the 680 from?
Old 10-25-2005, 08:51 AM
  #797
Irfo's Avatar
It's the $110 destination charge increase my New Hampshire dealer quoted me (see here) added to the $570 I last knew the NH destination charge to be.
Old 10-25-2005, 09:45 AM
  #798
Any ideas why does NH need more money for dest charge?
Old 10-25-2005, 10:49 AM
  #799
jkozlow3's Avatar
Destination charges don't vary by state as far as I know. They average it out so everyone pays the same. Sounds like someone's dealer is ripping them off!!
Old 10-25-2005, 11:01 AM
  #800
STL
STL's Avatar
Or maybe it's set to increase another $65.
Quick Reply: 2006 TSX Info...
