93 vigor rpm's going crazy
Old May 26, 2009 | 12:42 PM
andrew070489's Avatar
hey guys, for my 5spd swap i am fixing the vigor for a friend. the rpm's shoot all over the place, this would be the AICV correct? thanks in advance for your help
Old May 27, 2009 | 09:17 AM
KaMLuNg's Avatar
if it is a seeking rpm... then usually it is related to a vacuum/air leak somewhere... i would start with the ICV first...
Old May 29, 2009 | 10:18 AM
^ seeking rpm? it shoots up and down randomly, but runs solid. also none of the binkers, signals even work... what fuse or relay would fix that?
Old May 29, 2009 | 11:39 AM
TLin401's Avatar
'13 Hyundai Sonata
Originally Posted by andrew070489
^ seeking rpm? it shoots up and down randomly, but runs solid. also none of the blinkers, signals even work... what fuse or relay would fix that?
Most likely the relay. Check the fuses, take the bulbs out to see if they are still good and if not then it is the relay.
Old May 29, 2009 | 12:16 PM
whats the relay called.. im going to the yard tomorrow to get some misc parts i need. BTW both cars are being dropped off on sunday and should be complete by next wednesday.
Old May 29, 2009 | 10:41 PM
TLin401's Avatar
'13 Hyundai Sonata
The relay is called a relay. When I went to go get one for my fog lights they knew exactly what I was looking for and they told me just to go find it myself. I told them that I couldn't find it, pocketed it for nothing, and went home.
Old May 31, 2009 | 05:24 PM
TexasHonda's Avatar
RPM fluctuations can be due to bad ignition parts; spark plugs, wires, cap, rotor, ignitor. Missing can cause rpm fluctuations. Any drivability issues woudl suggest ignition parts are suspect.
RPM fluctutation could be due to failing RPM gauge in the instrument panel. This seems more likely as you describe. Look for used part at car-part.com near your zip or mail order.
I'm not aware of any relay that would affect the RPM indication.
good luck
Old Jun 1, 2009 | 09:05 AM
replaced plugs, wires, aicv and some other misc parts. runs like a charm
DerrickW
Nov 15, 2015 05:52 PM
Houston
Oct 8, 2015 01:27 AM
wubly
4G TL Problems & Fixes
Oct 6, 2015 02:45 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
