1998 2.5 TL Knock Sensor
Old Feb 5, 2008 | 08:56 AM
llg114's Avatar
My OBD-II scan read the code for low-input of the knock sensor. Where is this located on the engine? How is it replaced?
Old Feb 5, 2008 | 12:25 PM
TexasHonda's Avatar
What OBD2 scan code was read? I'll check this evening when I can refer to my Acura shop manual.
Most likely under the intake manifold. Acura loves to put stuff "out of the way" there.
good luck
Old Feb 5, 2008 | 06:19 PM
TexasHonda's Avatar
Front knock sensor is on cylinder head just forward of front intake runner on intake manifold. Rear knock sensor is midway along cylinder head above the intake manifold runner slightly.
good luck
Old Feb 6, 2008 | 08:27 AM
llg114's Avatar
good luck
I was something like P037 and under it read, "01/01". When I referred to my shop manual, it read, "knock sensor - low input". I'll do it again to night to make sure I have the right code.
Old Feb 6, 2008 | 08:09 PM
llg114's Avatar
good luck
The code is P0327 - Front knock sensor circuit low input
Old Feb 7, 2008 | 04:56 PM
TexasHonda's Avatar
Unless there is wiring damage, the foward knock sensor (see location above) will need to be replaced.
good luck
Old Feb 8, 2008 | 08:08 AM
llg114's Avatar
good luck
OK, cool, thanks for the help. I'm assuming the sensor can only be bought at a dealer? Or are there auto parts stores online who sell it? Also, do I need any special tools? Thanks again.
RobbDizzle
Oct 15, 2015 11:16 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
thegipper
Sep 28, 2015 01:01 PM
johnpancakes014
Sep 27, 2015 12:58 PM
STL TL-S
Sep 23, 2015 08:52 PM
