1998 2.5 TL Knock Sensor
What OBD2 scan code was read? I'll check this evening when I can refer to my Acura shop manual.
Most likely under the intake manifold. Acura loves to put stuff "out of the way" there.
good luck
good luck
Front knock sensor is on cylinder head just forward of front intake runner on intake manifold. Rear knock sensor is midway along cylinder head above the intake manifold runner slightly.
good luck
good luck
good luck
good luck
good luck
good luck
Unless there is wiring damage, the foward knock sensor (see location above) will need to be replaced.
good luck
good luck
johnpancakes014
09-27-2015 12:58 PM
STL TL-S
09-23-2015 08:52 PM
