Tweeters by the cabin light
Old Jul 2, 2004 | 08:36 PM
youngTL's Avatar
Registered Abuser of VTEC
Does anyone know how to pop off the little thing surrounding the cabin light so I can change the 2 tweeters on my 2.5TL? I just need to know if it's a major pain in the ass or if it's an easy thing to do. Or where I can find a diagram. Any help is highly appreciated.
Old Jul 2, 2004 | 10:15 PM
oulaw29's Avatar
Attorney- Will Sue 4 Food
I have heard that just bout everyone that bought after market speakers pulled their tweets out after they mounted them in facotory spot and either door or top of dash mounted due to the aftermarkets being too damn loud even with the treble turned all way down.
Old Jul 2, 2004 | 11:36 PM
youngTL's Avatar
Wow thanks for the info...I'll have to find out which ones the stock ones are. That's what I really wanted anyway because one of mine is dead.
Old Jul 2, 2004 | 11:51 PM
HQuakers's Avatar
giggity giggity giggity
Yeah, dont put in aftermarket tweeters up there. The speaker location is very close to your head/ears, and it gets to be extremely loud.
Old Jul 3, 2004 | 12:16 AM
Ken1997TL's Avatar
I've read that the impedence is different for the 2 tweeters and 2 mids, thus making it a lot louder than it should be. Not sure how to get around this as I'm not an audio expert.
Any ideas? I have those 4 speakers disconnected until a proper solution is found, if ever.
Old Jul 3, 2004 | 03:57 AM
Mikes96TL03CLS's Avatar
Ya for a while I didn't know those were tweeters.
Old Jul 3, 2004 | 06:41 PM
DoUbLe0's Avatar
ken you talking about the 2 tweeters above you and the 2 tweeters in the dash??
Old Jul 3, 2004 | 09:37 PM
Ken1997TL's Avatar
The 2 above are actually midrange speakers that act as a center channel with the stock player Pretty cool huh?
The tweeters are the 2 on the dash that reflect against the glass.
Old Jul 4, 2004 | 12:40 AM
DoUbLe0's Avatar
i see yeah i got all 4 of them to work its pretty simple!!! if i have the time to take out my deck and take some pictures ill would post them up!!
Old Jul 4, 2004 | 01:22 AM
demons rage's Avatar
o_o it seems like a few of my tweeters are dead.. cuz even /w treble at max.. it doesnt sound that great -_-
Old Jul 5, 2004 | 10:17 AM
youngTL's Avatar
You can add a variable resistor if you can find one that fits. It would work like a volume knob kinda.
Old Jul 5, 2004 | 02:15 PM
Cornflake's Avatar
Reppin' the T-Dot!!
I wouldn't hook up the center tweeters, they are set up as a center channel and unless you really know what you're doing with regards to sound quality, levels, etc. you could end up with these being way louder than they should be and affecting sound quality in a negative way. More isn't always better, especially when it comes to speakers in a car. There CAN be too much of a good thing. But in any case if you want to and you like the weay it sounds, then hey fire it up! just remember that you'll now be hearing the same left channel from the tweeter on your dash on your left side and that other one on your right above your head, so stereo separation will not be too good!! (Unless you set it up properly as a center channel, which the factory system does with the aid of a DSP.)
Old Jul 5, 2004 | 04:00 PM
youngTL's Avatar
I HAVE the factory system and I'm getting replacement STOCK speakers. I tend to keep my vehicles stock.
Old Jul 5, 2004 | 04:37 PM
Cornflake's Avatar
Reppin' the T-Dot!!
OK then, fair enough. If that's all you're doing I don't think it's even worth it to change those ones dude. Change the dash ones for sure, but those ones are just center channel, and don't get too much power as it is. I would just say it is not worth the $$$$, but if you've got some tweets that will fit lying around, then by all means chuck them in.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
akbears15
15
Nov 5, 2015 07:06 AM
sockr1
Oct 1, 2015 01:31 AM
