Speeds and RPM
Speeds and RPM
I think my OD gear isn't initiating (SP) and i thinhk thats why my gas milage is so
.. Wats you guys rpm at 60,80,and 100? Anyone else have this problem?
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Is this a 3.2TL or 2.5TL?
If OD is not working, the Trans Control Unit (TCU) should set a code; P0740 (hydraulic fault) or P1753, 1758 (LockUp solenoid A, B electrical fault. The D4 light may flash and the Check Engine Light should illuminate. I've had P0740 on my 2.5TL for a while. Not much to do except overhaul the trans, but it shifts fine otherwise so I live w/ the fault. Only impact is reduced gas mileage when driving on trips, perhaps 10-15 % lower mpg.
good luck
good luck
AZ Community Team
Received 7,770 Likes
No offense, but if you are regularly between 80 and a 100, I'd guess that's your gas mileage problem.
Originally Posted by KaMLuNg
~Cheers~
P.S. This is Go90go, forgot to log Ken out again. My alternator cable got loose again so I'm here to tighten it and actually put a lock washer on it this time,
lol but its wierd because I had 2 almost full 14.5-7 gallon tanks back to back trying to take it easy and back at E i was at 260 miles. Then I said F this and drove regular and still got the same amount of miles. its wierd...
Originally Posted by desired_speeds
Yeah, I checked last night and that's where I'm at, too.
~Cheers~
. All of my tools are with a friend who needs his car up and running by Wednesday for SILV!
~Cheers~
大日本帝国
i am surprised that the 3.5 revs exactly like the 3.2...
~Cheers~
大日本帝国
Originally Posted by flyinghighagain
in cruise control i was doin 120km today which equaled 3k rpm so i guess thats alright for my 2.5
~Cheers~
大日本帝国
Originally Posted by Go90go
See, told you.
~Cheers~
~Cheers~
~Cheers~
I have a spreadsheet I put together to calculate slip between engine and trans torque converter, based on tire diameter, 2.5TL gear ratios. It says that 120 kph & 3000 rpm are almost a perfect match (< 1% slippage). So if your tire sizes are stock, then everthing is fine.
In my case, there is a torque converter lockup problem that sets code P0740. No fix short of pulling the trans so I live w/ it.
If you want the spreadsheet PM w/ your email and I'll email it to you.
good luck
good luck
DerrickW
11-15-2015 05:52 PM
