problem w/the idle
Old Feb 27, 2002 | 06:15 PM
problem w/the idle
Does any of your guys tl idle at 1500 when you start up your car and it its in park? My car idles at 15 grand then when i put it in gear it drops to 11 grand.....Only after driving it for a couple of minutes does the idle drop below 1 grand....(this is normal idle) *also i'm not touching the gas pedal when it revs at 15 grand.....
Any help will do.....Should i take it in to Acura? My car is still under warranty...........or is it a problem that is able to be fixed in my garage........thanks in advance......
Old Feb 27, 2002 | 06:22 PM
96TL's Avatar
Ex-Mod
Does it do that only if its cold? Mine idles higher when its cold but I dont remember how high. It sounds normal to me.
Old Feb 27, 2002 | 07:04 PM
Yeah, it revs higher when it is cold but it also revs high kinda high when it is warm....Do you have any idea what is the cause of this......
Old Feb 27, 2002 | 07:10 PM
Wampum's Avatar
Mine does it too when its warming up. After it warms up it drops below 1000. When I put it in drive it drops to like 600rpm
Old Feb 27, 2002 | 11:14 PM
96TL's Avatar
Ex-Mod
It might just need an idle adjustment. Take it to the dealer or a mechanic shop. It shouldnt be expensive.
Old Feb 27, 2002 | 11:19 PM
TLBaller's Avatar
speaking of idle, i have a problem with mine. everytime i start my car to get the engine warmed up, my muffler rattles for like 5-10 seconds then it stops. has this happened to any of you? im thinking its my subs in my trunk thats causing it. i mean, i dont turn on my subs when i start my car but im thinking that the rattling of the trunk, due to my subs hitting, it causes the hinges of the muffler or SOMETHING to rattle. any ideas???
Old Feb 28, 2002 | 02:55 AM
I herd of subs makeing the hinges in your doors loose, so i guess it could apply to the exhaust.......By the way thanks for your guys help......
Old Feb 28, 2002 | 07:04 AM
check your O2 sensor at the intake...same stuff happened to me.............aloha.......
Old Mar 4, 2002 | 06:58 PM
KaMLuNg's Avatar
that is very normal... cold engines always run higher that is the point of warming up the car... while u warm up the car for a few min u can see the tach actually drop down.. when car is at idle and warmed up car should be around 700... if it isn't then the timing should get checked with a tune up or just adjust the RPM screw on the throttle...
Old Mar 4, 2002 | 07:01 PM
unx979's Avatar
wow you guys are idling high. after running the car for a little bit my car usually idles at 400 rpm.
Old Mar 4, 2002 | 10:35 PM
kwb377's Avatar
Re: problem w/the idle
... My car idles at 15 grand then when i put it in gear it drops to 11 grand...
Holy $hit! Are the pistons still in the block?!
Just kidding...
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
TL14
Sep 24, 2015 04:37 PM
