Help..........
Old Mar 23, 2005 | 06:26 PM
maximus23's Avatar
4th Gear
Help..........
A few weeks ago, I put premium gas in my 96'TL which usually runs fine on regular unleaded but ever since I used premium gas, the car has been making a "pinging" noise when accelerating. I took it to the shop and they said it was just bad gas and I should go back to using regular unleaded. It been a few week and the noise is still there so I'm wondering if anyone has come across problem if so, what I can do to fix it.
Old Mar 23, 2005 | 06:36 PM
dubcnea's Avatar
Hurricane Game
i cannot see why premium would do that to your car. that is what your car is supposed to take (for the 2.5 anyways). for that engine anyways, you usually don't get ping, but would if you used the lower grade gas. go for a gas that has a higher octane rating if you can. or think about using just a bit of octane booster. also using some FI cleaner or gas system cleaner couldn't hurt either.
Old Mar 23, 2005 | 06:45 PM
maximus23's Avatar
4th Gear
just out of curiosity, on the same day i changed my spark plugs as well. I wouldn't think this would have anything with the noise but wanted to see what you think.........
Old Mar 23, 2005 | 07:02 PM
KaMLuNg's Avatar
unless the plug isn't catching the wire into the distributor.. u make sure of all the connections????
Old Mar 23, 2005 | 07:08 PM
maximus23's Avatar
4th Gear
the connection should be fine but i'll ck it again.....however if there's a connection issue then is it possible to have the pinging noise?
maximus23's Avatar
4th Gear
while accelerating?
Old Mar 24, 2005 | 09:47 AM
barracuda's Avatar
does it also "shiver" while accelerating at a certain RPM? it could be a bad spark plug, connection or (although unlikely) wrong sequence.
Old Mar 24, 2005 | 10:55 AM
Cornflake's Avatar
Reppin' the T-Dot!!
Did you check the gapping on the spark plugs? That could cause the pinging.
Old Mar 26, 2005 | 01:13 PM
TL-Ridaz96's Avatar
How often do you guys change your spark plugs?
Old Mar 26, 2005 | 02:08 PM
Ken1997TL's Avatar
I change my plugs every 100,000 miles (platinum)
30,000 for copper plugs.
Old Mar 26, 2005 | 02:09 PM
Ken1997TL's Avatar
I'd check that first.
sanjayjp99
Jul 28, 2011 02:34 PM
mishka420
Mar 31, 2001 05:09 AM
