Tail lights not working!!!!
Old Feb 2, 2014 | 10:41 PM
Le93nd's Avatar
I have a Acura RL 2002 sedan.
Okay so i checked everything i can think of...i started having problems with my tail lights and my passenger front marker light. After 1 week of driving my car other things started failing, all of the back lights went out on my car "Everything" Then it was put on a computer so i had to replace the following things. I had to replace headlight switch,multiplex control unit, shift lock solenoid,relays,light bulbs,alternator,battery,tail light relay boxes, After replacing the stuff i mentioned. My brake lights,signals,hazards are now working but my tail lights still aren't working. All of the relays & fuses/bulbs are good but i still don't know why my tail lights don't work. my cigarette lighter doesn't work, back seat ceiling interior lights don't either. Does anyone know what it can be??? please i really need some help thank you very much if you can help.
Old Feb 2, 2014 | 10:43 PM
Le93nd's Avatar
Oh and license plate lights don't work either.
Old Feb 3, 2014 | 09:14 AM
RPhilMan1's Avatar
2024 Honda Civic Type R
Mod move to 1G RL section?
https://acurazine.com/forums/1g-rl-1996-2004-77/
Old Feb 3, 2014 | 09:38 AM
MyNameIsEarl's Avatar
Perhaps one of the relay in the engine bay fuse box went bad?
Old Feb 3, 2014 | 08:02 PM
3.5RLv-tec?'s Avatar
What about your parking light? If it is not working too,then it is the fuse in your engine bay.
Old Feb 21, 2014 | 03:24 PM
acura35rl's Avatar
8th Gear
does your horn work? There is a fuse under the hood that connects the horn, tail lights and shifter. I had to replace my horn that is underneath the air cleaner. 1997 acura 3.5rl
Old Dec 25, 2019 | 06:13 PM
Keilasacura's Avatar
6th Gear
wondering if you solved the issue because i also cant figure out why my tailights DW
did you fix the tailight issue please let us lnow
Spoiler
Old Dec 25, 2019 | 06:14 PM
6th Gear
i have tried everithing from replacing switch bulbs checking connectors ground etc
Old Sep 13, 2023 | 10:58 AM
HJac0916's Avatar
6th Gear
Fixed! (Well, for mine anyway)
I had the exact same issues. So I’m currently getting mine fixed on my 2002 Acura RL. It turned out to be a broken wire located under the drivers side tire. Hope this helps anyone still struggling to find the cause.
Old Sep 16, 2025 | 07:28 AM
seansisson1021's Avatar
My parking lights are working when unlocking and locking car nothing else
[QUOTE=3.5RL my headlights tail lights and running lights stopped working they work when I lock and unlock the car but not when started breaking etc interior lights are good everything else works
HJac0916
First Generation RL Photograph Gallery
Aug 7, 2023 09:59 PM
sickspeed3g
Mar 11, 2021 10:11 PM
nazzo
1G RL (1996-2004)
Jan 21, 2012 09:37 PM
supergeri
Apr 12, 2010 08:07 PM
Jimmay
1G RL (1996-2004)
Jun 18, 2008 11:51 AM
