Help! Tail lights, 4 side marker and front amber lights not working.
Old Aug 6, 2012 | 10:41 PM
sickspeed3g's Avatar
9th Gear
Hey guys!
I tried searching for a while on this topic but couldn't find anything in the 3rd generation section. Maybe I'm blind, i dunno but I did make one hell of an effort to search around for help topics.
So my front amber lights, tail lights and side markers are not fully working on my 04 TL. the reason why I say fully is because the when I brake the tail lights come on and when I signal the front ambers and tail light signals work. The side markers don't stay on at all.
I'm a bit confused as to what the problem may be? Problem with ground? Relay? Short? I don't really know as I am not too inclined with electrical or wiring.
I am the second owner of this vehicle and the first owner actually put an 08 type s front end on it with fog lights but the fog lights are not functional as there is no switch inside for it. These are all the mods he has done to the car as far as I know.
So can somebody shed some light as to what the problem may be, perhaps may be give me some possible scenarios? what to look for?
Any help would be appreciated!
Thanks a bunch guys!
Old Aug 6, 2012 | 10:56 PM
fraiolim07's Avatar
I assume you have the lights turned on? If the switch is off those lights will never come on of course.
And maybe the fogs come on with the stock switch on the stalk if the previous owner did that mod.
Old Aug 7, 2012 | 12:28 AM
9th Gear
Yes the lights are switched on but the tail lights, front side amber lights or all 4 side markers don't come on.
The only time the tail lights and front amber lights come on is when I brake or turn my turn signals on.
They were all working before we had some rain, and I did some spirited driving on the highway. Thats the last I remember them working.
As for the fogs, I have no clue? I am going to ask the guy I bought it from.
Old Aug 7, 2012 | 01:14 AM
roof2006's Avatar
It's a fuse. The usual way to describe what you're experiencing is "the parking lights aren't working." I don't know which one it is on the TL - but that's where you should look first.
Old Aug 7, 2012 | 08:22 AM
9th Gear
Thanks bud! I appreciate your help!
Old Aug 7, 2012 | 12:55 PM
9th Gear
***UPDATE***
I've replaced the #4 10a fuse underneath the hood 3 times and it keeps blowing.
I think it may be a short somewhere.... I dunno?
Any thoughts guys?
Old Aug 7, 2012 | 01:07 PM
pohljm's Avatar
yes there is a short somewhere! you do know! now your just going to have to try and trace it. start at each light and check the connections work your way back and look for any signs of a short.
Old Aug 7, 2012 | 03:08 PM
guitarplayer16's Avatar
Was just about to mention that fuse for you - glad you found out it was the fuse.
I'm assuming it was like this when you bought the car.
I'm willing to bet it's the wiring job for the fogs.
Old Aug 7, 2012 | 04:24 PM
pohljm's Avatar
^ +1
Old Aug 9, 2012 | 08:37 AM
9th Gear
I've check and tested all the lights that are out with a voltage meter and tester light... All are fine and working... So the short has to be some where in the front perhaps?
No the parking lights were working when I bought it... It could be the foglights, they weren't functional when I bought the car so I don't even know of they are wired to anything, Ill have to check.
Old Aug 9, 2012 | 08:43 AM
9th Gear
Does anybody know what colour the "negative parking light" wire on an 04 TL?
On the 05-08 they are black/red... But I couldn't a black/red wirew under the steering wheel where the ignition is.... Is it maybe a blue wire??
I need a schematic wiring diagram!!! I suck at this electrical stuff!!
Old Aug 9, 2012 | 04:21 PM
blueracer17's Avatar
The ground (negative) for the parking light on an 04' TL is actually black going from the light to ground and red/black going from the control module/relay to the parking lights.
Old Aug 9, 2012 | 08:30 PM
9th Gear
Thanks so much bud! Appreciate the insight!
Old Aug 9, 2012 | 08:40 PM
I need to clarify a bit, the power in to the light is red/black. The ground is black. I looked at the wiring diagram right after work, I have no idea what I was thinking. Sorry.
Old Aug 10, 2012 | 08:43 AM
9th Gear
Thanks for clearing that up!
Old Aug 10, 2012 | 09:46 AM
The first thing I would have checked for is the fog lights, especially since you know the fogs don't work.
2004 TLs DID NOT come with lower fog lights.
The only way you could get lower fog lights to work is if you have a wire harness that's piggy backed off a trigger wire which is most likely your parking light wire.
Old Aug 10, 2012 | 11:16 AM
9th Gear
I see what ur saying! The car has an 08 type s front end on it. The only thing is, the fogs weren't working to begin with, but the parking lights were working but all of a sudden crapped out.
But I will check the fog lights, just havent had time to do it
Old Dec 26, 2019 | 12:55 AM
Keilasacura's Avatar
6th Gear
did u get the fix im in the same scenario now ive done all you mentioned and cant the
Hey guys!
Thanks a bunch guys![/QUOTE]
Old Dec 26, 2019 | 01:00 AM
6th Gear
please help i have same prob any solutioon yet?i have tried everithing
i need the solution did u find it i have same problem please help ????????see what ur saying! The car has an 08 type s front end on it. The only thing is, the fogs weren't working to begin with, but the parking lights were working but all of a sudden crapped out.
But I will check the fog lights, just havent had time to do it [/QUOTE]
Old Dec 26, 2019 | 05:17 AM
WDPanda's Avatar
Check the fuse box under the dash and also under the hood.
Old Mar 11, 2021 | 10:11 PM
I2canfix's Avatar
Side markers not working
If someone installed after market stuff I’d suggest looking for frade open wires that may have touched! Otherwise Change out signal light sockets!! This will most likely fix the side marker and tail light issue, as for the fog lights at tail light relay take a test light hook to positive on battery and make contact with each of the prongs on fuse box under hood!! Fog lights should light up also look on fuse box find fuse to fog lights and do the same they should light up!! If they don’t put new bulbs I’d start with one as they ar 25.00 each!! Or get at junkyard like I did!!
supergeri
Apr 12, 2010 08:07 PM
ChicagoBurbs
Aug 6, 2008 07:15 PM
Jimmay
1G RL (1996-2004)
Jun 18, 2008 11:51 AM
98 CL
Apr 29, 2008 01:13 PM
