Rough Idle...help
Old Oct 20, 2020 | 07:03 PM
mellowcream's Avatar
6th Gear
Rough Idle...help
Hello guys
i have an 03 RL (c35a engine, 200k miles). it has a rough idle, almost feels like a slight misfire, no codes. I've replaced the fuel filter, cleaned the throttle body, cleaned the EGR port, changed all 6 spark plugs with OE Denso 3275's, checked for vacuum leaks to no avail, the car runs fine under load - cursing down the highway and in town. happens in neutral and in drive. Any ideas?
I've just replaced the timing belt and water pump, so I'm hoping to keep this car for awhile, but the idle is driving me crazy...maybe ignition coils?
Old Oct 20, 2020 | 11:07 PM
idle air control valve perhaps needs cleaning
Old Oct 23, 2020 | 06:51 PM
Babafats's Avatar
Have you removed the intake manifold disassembled it cleaned all the gunk out, cleaned the egr pipe behind the engine These engines are sensitive to dirty passages and a dirty intake manifold. Is the pcv valve good? I have a 2000 with 256k and have performed this service twice in 2012 and 2020
Old Nov 7, 2020 | 10:37 PM
I2canfix's Avatar
Idle
Put gallon of laquar thinner with ten gallons of fuel! As it is major ingredient in fuel injector cleaner! Run till empty! Sounds like a clogged injector/intake path, also do a relearn! Pull bot ecm ecu fuses out replace after a couple minutes idle at 3,000rpm. For 3 minutes, as cleaning tb may have taken it out of wack. Also using the laquar thinner will help with cleaning the ice! Or open it and manually clean it, good luck.
beancount1
3G RDX (2019+)
290
Oct 17, 2023 03:58 PM
OnlyDaanish
Jun 5, 2017 12:29 PM
geniusnouman
Nov 22, 2011 11:51 AM
kvan2007
1G TSX Problems & Fixes
Apr 29, 2010 10:05 AM
shomeyrwit
1G CL Problems & Fixes
Oct 23, 2007 07:48 PM
