02 acura rl downstream 02 sensor
Hey i went to go replace the downstream 02 sensor on my 02 rl 3.5l and found that the connector for the sensor is tucked up into the cab of the car where is the connector located inside the car and what do i have to take apart to get to the connector
02 sensors
I'm replacing the O2 sensors cuz I got codes for them and I just got the car so I want to make sure all the sensors are good on the car and thank you for the information on where it's at I appreciate it
Yeah cuz I can't remember the code right now but I believe the codes Throne were for the coolant temperature sensor and the O2 sensor is running The Gather so I deleted them once in a hundred miles later both of them came back I replace the coolant temp sensor and then the code came back for the O2 sensors so I'm just going to replace them all
Not sure you are having the same problem but I got a code P0141 “Secondary heated oxygen sensor” on my ‘03 RL at 182k miles. I bought a Bosch sensor and spliced and soldered the wires under the seat (though the sensor came with some sort of universal connector but I did not use it).
Code went away and never bothered me again. I’m at 254k miles now.
