Weird Noise in Cabin
Old Mar 14, 2012 | 09:33 PM
hotbryan333's Avatar
I have observed some weird noise in the engine bay or inside the cabin.
As i was pulling on my driveway, and turned my wheels into the right side and i heard some kind of buzz kind of noise it happened so randomly that i could not duplicate, nor re-create but it was certainly there, it was happening intermittently and it went away. It was very similar to the side mirror adjusting itself downwards when backing up.
could anybody chime in for any advice?
Thank you
Old Mar 15, 2012 | 06:52 AM
DRR98's Avatar
Was it the antilock brake control doing the start up hum?
Was the car just started, and moving slowly?
Old Mar 15, 2012 | 10:47 AM
Kaze66218's Avatar
Copy cat shinobi
There's what drr said, and also that might be cavatiation in the power steering pump. Also another thing could be could be the dreaded vacuum vent controls.
Old Mar 15, 2012 | 03:49 PM
When you just turn on the car and getting ready to move, there is a humming sound in the steering wheel. Its not that.
However it is somewhat similar sound, but intermittently. Its like a frog gulping or something. it happens not during the operation of the car, but when it is coming to a stop specifically to my driveway after turning right into the garage... LOL
I have no idea where it is coming from, i tried to video this thing but no luck, its not vibration coming from the steering wheel, sorta of grinding noise............ I know what my dealer is going to say, Can't duplicate the problem and say bye bye with a $100 bill.
Is it possible that i have a vacuum leak?
Should i pursue this sound further with my mechanic or do you guys think that it is okay to neglect....?
Old Mar 30, 2012 | 11:29 AM
08FLrdxSH-AWD's Avatar
KCCO
I have been recently (since it got cold) had issues with a creaking sound coming coming from (or seeming to) the front suspension. without fail every morning that i drive to work and go over the speed bumps in my neighborhhod and occassionally i will hear it if i hadnt drievn it that day. the problem goes away when the car is warm. any ideas?
Old Oct 22, 2012 | 12:36 PM
tigersfa8's Avatar
I had another small problem where I turn on the recirculation button while driving on the freeway, and it would have a whistling sound. When I turn the recirculation button off on the climate control again, it would go away. Usually this occurs on the freeway. What may be the problem? It is not too big of a deal, but a little annoying at times.
Old Oct 22, 2012 | 03:27 PM
Mr Marco's Avatar
Originally Posted by Kaze66218
... Also another thing could be could be the dreaded vacuum vent controls.
This^
I've heard everything from "My power steering is making this...," to "Tire is making a fart noise." They all turned out to be the Fresh Air Vent in need of a lube.
Old Oct 22, 2012 | 07:41 PM
vaprea's Avatar
honda ABS 100%, I assume you were turning and braking.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
