Steering issue
Steering issue
I need a little guidance, just changed the power steering pump. Changed fluid with Honda fluid, no leaks everything was fine after the change. I was driving and the steering became hard almost to the point you couldn't steer any longer then went back to normal. At first I though it might have gotten air bound for a minute but it keeps happening. Not sure what could be causing this. Fluid is full and clean, no leaks, pump is not whining. Any thoughts would be great. Thanks Mike
I’m with the previous suggestion of air in the system. You can usually work it out by turning the steering wheel lock to lock and toppig off the reseroir as you do so. There is a Honda Accord procedure at OS bleeding. Note the procedure has you jacking up the front end, That really isn’t necessary; it is done to avoid getting isolated wear spots on the tires and to make it easy to turn the steering wheel. When I’ve done the procedure, I just drive over a section of newspaper and then the steering wheel turns easily.
Thank you for the feedback, I have been reading that there was an issue with a or multiple O rings. Is it on the pressure side or the return side? I went for a ride with the car and drove about 30 miles and everything was fine, then it happened again with the hard steering. I am starting to believe it must be getting air in the system from somewhere hence the "O" ring question. Any insight would be helpful, thanks again for everyone's time.
The original problem was the unit was whining and after further inspection, I could hear that the main bearing was making a grinding noise. I never had an issue with the steering before I changed the pump. That is why I was asking about the "O" rings. I just replaced the "O" rings 5 minutes ago and didn't get 2 miles down the road and it happened again. I was thinking that it might be a bad pump when I saw this post. I going to get another one and see if that solves the issue unless someone has something else I can try. Again thanks to the few members who help me out with the issue.
The following 2 users liked this post by mmattie193:
Chopperpilot (10-08-2024),
DCS (10-10-2024)
