Starter problems
Old Jan 20, 2012 | 10:27 AM
darsimp4's Avatar
5th Gear
Starter problems
2007 RDX having problems starting. It seems that everyone having problems with diagnosing this. There is no rhyme or reason when it starts. When I turn over the engine (at times)- there is nothing- not a sound, but all the lights, radio, etc. works. At other times, it just fires up like nothing. Sometimes if it won't start, I wait 5-10 minutes and it starts again! The battery has been changed and alternator checked. All good. Wondering about the security system? Has anyone else had this problem? I reprogrammed the key fobs. The security system light goes on (flashes) when I lock the car.
Old Jan 20, 2012 | 12:27 PM
XLR8R's Avatar
It sounds like the starter relay may not always function. When you catch it not starting, open the hood while someone turns the key and see if you can hear the starter relay clicking.
If the relay doesn't function, the starter will not be powered, but everything else will still work. The relay is inexpensive and you can replace it yourself.
Otherwise, there may be loose connections at the battery or starter cables.
What do you mean about the security light? It is meant to flash when you lock. Or do you have an aftermarket system?
R*D*X*'s Avatar
I also have the same problem last night, My brother's Infiniti EX and my RDX parked inside our garage for 2 weeks and last night when i start my car it doesnt start at all although my radio and light is still working. FYI i also have new battery bought it 2 mos ago (Red Top Optima) My brother's Infiniti start without a problem even his battery is 2 yrs old. If i go to the dealer they will tell you that it's normal because the car was sitting in my garage for 2 weeks but it didnt happend to my brother's car..... something is draining the baterry even the car is off and the alarm is off also....
Old Jan 20, 2012 | 12:28 PM
R*D*X*'s Avatar
it did start after i jump start my car.
Old Jan 20, 2012 | 07:12 PM
darsimp4's Avatar
5th Gear
Well, with the security system, one of the mechanics that I spoke with said that the whole issue could be related to that?
Old Jan 20, 2012 | 07:13 PM
darsimp4's Avatar
5th Gear
I should mention that my RDX would not start when we tried to jump start it
Old Jan 21, 2012 | 04:42 PM
XLR8R's Avatar
OK, but is the system OEM or aftermarket?
You are definitely not getting power to the starter motor itself. Other than the security system, (?) check for tight cable connections and the starter relay.
Old Jan 24, 2012 | 04:48 PM
darsimp4's Avatar
5th Gear
Took it to a mechanic yesterday- car fired up immediately after leaving the flatbed (towed). This was immediately after leaving my driveway where it was not starting at all for the past 4 days...Mechanic said that they can not find a single thing wrong?? Phoned Acura and the mechanic there told me that it could be a master cylinder problem with the ignition. He said that the key could be worn and not making the connection? Has anyone had any experience with this or ?
Old Jan 24, 2012 | 08:26 PM
Ryan8886's Avatar
6th Gear
No problem like that with mine and I just turned 100K miles. however....it sounds suspiciously like the problem i had with my old '94 Camaro when GM had the old Pass key II security system...turned out to be a bad ignition cylinder. I know we're decades removed from that now...but same idea...sounds like your key is not communicating properly with the security system to allow a start.
Old Jan 26, 2012 | 07:52 PM
darsimp4's Avatar
5th Gear
Day 2 after having it at mechanic and it is starting like a charm....frustrating- to say the least! Where do I go from here? Any suggestions? Can't rely on the vehicle. Do I wait until it doesn't start again?
Old Dec 18, 2017 | 08:47 AM
grsims20's Avatar
I know this is an old thread, but hopefully somebody will see it. Which one is the starter relay?? I can't identify it by the diagrams, etc.
Here's a diagram of the under-hood relay box (near the bottom of the page): https://www.justanswer.com/acura/7n3...placed-ac.html
And here's the fuse diagram: Acura RDX (2006 ? 2008) ? fuse box diagram | Auto Genius
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
agupta3224
Sep 22, 2015 08:08 PM
