programme key
Old May 26, 2009 | 08:24 AM
derumeaux's Avatar
programme key
I lost my key and have now a new one. The dealer wants me to charge 55 dollars just for programming. Are theire any instructions how to programme it?
thanks
Old May 26, 2009 | 03:03 PM
Samdog-1's Avatar
For another 20 bucks you can get the Helm Service Manual. The key coding procedure is in there along with everything else you'd ever want to know.
The procedure is a DIY, but it's a little complicated depending on how many key units you have. The computer has memory for six key units. So if you are using only one because you lost one, that one must be programmed six times to delete any code from the lost key. If you bought one to replace the lost one and have a total of two then each of the two must be programed three times to delete any old code. In other words you have to fill all six memory positions with an active key to delete the code from the missing key.
Programming is simple with no tools, but the timing and sequence has to be right or you might delete the existing key.
Get the book.
Old May 27, 2009 | 10:36 AM
number84's Avatar
why not share the information here? isn't that what forums are for?
Old May 27, 2009 | 02:37 PM
derumeaux's Avatar
You are right!
I just came back fromthe dealer and he charged me 30 dollars.
thanks
Old Mar 26, 2010 | 01:13 AM
nwizard's Avatar
8th Gear
guys, I just bought new key and have old one. But I do not have Acura dealer here in Kazakhstan. can you help me and give instruction how to program new key ?
Old Apr 8, 2010 | 03:25 AM
nwizard's Avatar
8th Gear
any help ?
Old Apr 8, 2010 | 10:12 AM
R*D*X*'s Avatar
You can go to any locksmith, they also know how to program keys... i did this on my other car before :p
Old Apr 9, 2010 | 02:01 AM
nwizard's Avatar
8th Gear
I found the info and share it
http://www.wikihow.com/Program-Facto...emote-Key-Fobs
add to FAQ please. the problem is solved
Old Apr 10, 2010 | 10:28 AM
eg5's Avatar
eg5
user title goes here
this procedure is to program the remote portion of the key. this does not program the immobilizer part of the key.
if the old owner of the car still has that key, they can still open,start the car and drive off.
sucks you dont have a dealer out there.
Old Apr 12, 2010 | 10:44 PM
nwizard's Avatar
8th Gear
yes, that's right.. so it just a part of the solution...
Old Apr 20, 2010 | 05:04 AM
nwizard's Avatar
8th Gear
another question related... how to make the car "beeps" when I close/open my car ?
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
malvothegreat
Sep 29, 2015 12:38 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
bradgottaTL_88
Sep 25, 2015 01:04 PM
