Parasitic Draw also? Or is it my dashcam?
Old Aug 29, 2023 | 12:47 PM
acura1972's Avatar
Came here as my 2010 RDX with 130k kms (80k miles est) didn't want to start.
I suspect it's the newly installed dashcam (installed 1 month ago) AND car sitting for >1 wk unusued.
As I charge the battery up right now (and am at home sitting on my computer waiting for time to pass), just wanted to see if I am "attacking" the problem correctly based on the symptoms:
a) literally when I turn the key, not even a sound, a click, nothing - only the brake light engaged sign lights up and then dashboard light (and the light dies slowly after).
b) VIOFO dashcam: I don't remove it from the lighter socket (I presume this is the culprit? - the manual did say it will not draw power - but I don't know if our RDX lighter socket does draw power even if engine is off)
c) I read other posts here indicating it could also be the bluetooth - but that is what I'll "attack" AFTER I make sure it IS the lighter socket drawing power from the battery
Please let me know if you think it's any other problem: eg starter, alternator etc... The engine does not even crank FWIW. Literally nothing save for some lights turning on.
Many thanks for your thoughts.
Old Aug 31, 2023 | 11:05 AM
Tomtwtwtw's Avatar
I doubt it is the dashcam, but if you are worried there are harnesses available that plug in-line with the rear view mirror wiring (assuming you have auto-dimming mirror). It's a cleaner install and there is no power supplied when the car is not on, so no way for the camera to drain the battery.
Old Sep 5, 2023 | 08:53 AM
yanga001's Avatar
Invest in a multimeter and check the battery between starts for like a week. Should help you isolate the issue. Ie disconnect the dashcam and check if the voltage drops, etc.
Old Mar 28, 2024 | 12:58 PM
acura1972's Avatar
After 6 months or so, it's a dashcam or lighter socket fluke and/or the battery -- I replaced the battery and it seemed like Kirkland battery has "deteriorated" in quality (or kirkland battery i got was a fluke)-- meaning: if the dashcam was indeed draining power, either the battery sucked (eg Kirkland) or this new battery from the CAA is better... how do i know this? well, i forgot to unplug the dashcam again for a week and this time, car started easily... FYI kirkland battery was only 1 yr old when it didnt want to start in the middle of summer last year...
PS I won't muck around with the bluetooth system for now, even if i don't actually use it at all...
penguins
1G RDX Problems & Fixes
30
Mar 21, 2024 10:12 PM
Redsrig
2G RDX Problems & Fixes
Nov 14, 2019 08:38 PM
Rdxsxy
Feb 9, 2018 04:11 PM
Longview
1G RDX (2007-2012)
Dec 10, 2017 04:37 PM
PiMpiN wHITe Cl-S
Nov 15, 2005 03:15 PM
