Help, emission check engine light is on again
Old Aug 27, 2010 | 11:15 AM
LYK's Avatar
LYK
3rd Gear
My 09 RDX is keep having this problem (emission check engine light on).
I think there were more than 10 times this year.
We bought our car back to the dealership and replaced many things like oxygen sensor, Torque converter, ECU etc etc....
And the problem still can not be fixed. My dealership also opened a file with Acura Tech Line to report the problem. And still they can not fix it....
ECU was replaced this Tuesday and the emission check light is on again this Thursday.
Any advise what I should do next?
Old Aug 27, 2010 | 12:59 PM
LuvMyTSX's Avatar
Simple thing, but do you make sure you twist the gas cap at least 3 times when filling your tank? If you don't twist it enough, the CEL will come on.
If this is not the problem, have they replaced the actual sensor for the CEL?
Do you know what codes they are pulling when the CEL is on?
Old Aug 27, 2010 | 01:32 PM
LYK's Avatar
LYK
3rd Gear
Yes, gas cap is not the issue. We know that from day 1 when we bought the car, we make sure we hear 3 clicked sound.
As told by the deal, we have different code every time. One code is for the oxygen sensor P1039? Something like that.
Old Aug 27, 2010 | 09:24 PM
737 Jock's Avatar
haole kama'a-ina
Well, P1039 is not an Acura code, it's a Ford specific trouble code.
But anyway, next time have the dealer tell you what the code is and what they plan to do about it.
Better yet, before you go to the dealer get the code read for free at Autozone. They can read all generic trouble codes with definitions and should be able to give you the Acura code (with no definition) as well. Check this link to define an Acura code: Acura Trouble Codes
Post the code and we will try to advise before you go in.
It's a bit perplexing to consider that the O2 sensor, torque converter and ECU might have all failed on a new car within one year. Have they considered that something might be causing false codes? A weak or intermittant power supply often causes all kinds of false codes in electrically sensitive modern cars.
Old Aug 28, 2010 | 09:54 AM
LYK's Avatar
LYK
3rd Gear
Oh, the code should be P0139 HO2S S2 Slow Response
Old Sep 22, 2010 | 06:47 PM
r7cgb's Avatar
I had the same problem before and I took it to one of the dealer here in San Diego. I was told that the reprogram the system, something like reflush and as of now did not appear anymore.
Old Sep 23, 2010 | 06:27 PM
mau108's Avatar
ya theres a software update to fix it, check the TSB's. I have been getting this in my 07 on and off, just haven't had time to go and update it.
Old Oct 10, 2013 | 11:38 AM
iamnaike's Avatar
hi guys,
i have a 2007 rdx turbo with 118k miles on it and these codes came up ( i got them from autozone)
p-145A
p-145D
p-2263
are these just censors? btw both catlyst convertors were change 2weeks ago.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
