faulty cluster?
Old Sep 22, 2020 | 12:19 PM
Cwhite87's Avatar
5th Gear
Question faulty cluster?
Hello everyone i have the 07 RDX w/ tech pkg,
I have recently noticed the battery dying regularly. If it isn't driven within a couple days the battery is dead.
I'm curious if this my be a result; when you turn off the ignition the cluster says "Goodbye" and disappear you lock it and there's a blinking red light on the radio and the left side of the cluster.
But.... if you open the drivers door only, lets say to retrieve something the cluster will say "Welcome" disappear and repeat over and over. if you shut the door it continues to say it over and over again. you physically have to put the key in the ignition turn on then off for it to say " Goodbye" before it will turn off. Has this happen to anyone else? anyone have any insight on this issue?.
i just saw a post on the blue tooth module so i will check that also.
Old Sep 22, 2020 | 12:32 PM
most likely it's the bluetooth module that is killing your battery
Old Sep 22, 2020 | 04:44 PM
Cwhite87's Avatar
5th Gear
Pulled it.. we don't use it no way. but the cluster still does that continuous scroll of Welcome
Old Sep 22, 2020 | 06:13 PM
is the battery good, holding 12.4 volts when the car is off?
Old Sep 22, 2020 | 09:33 PM
CSmoney28's Avatar
CSmoney28
Lightbulb
Try checking that pressure sensor for the drivers door
Old Sep 23, 2022 | 08:27 AM
JCash23's Avatar
I know this is old thread however I’ve been experiencing electrical issues recently, I’ve noticed the logo never saying goodbye unless insert key, I also have sat inside the car when everything is off the car is powered off to listen for any noises of hissing, bubbling, gurgling & I’ve noticed a sound that I can’t explain well kinda sounds like computer dial up just more of a faint sound like old computer’s dialing up internet connection) that’s the best interpretation I could think of lol….. it’s seems to definitely be coming from the dashboard cluster and there is nothing on in the car when I’ve observed the sound. Anyone have or find what this noise in the cluster could be??
psusmacko15
Nov 2, 2020 12:53 PM
Redsrig
2G RDX Problems & Fixes
Nov 14, 2019 08:38 PM
Acura TL Builder
Jun 26, 2018 06:57 PM
shocka04
May 2, 2011 01:30 PM
azn5ucka86
Jul 25, 2005 11:04 AM
