faulty cluster?
Hello everyone i have the 07 RDX w/ tech pkg,
I have recently noticed the battery dying regularly. If it isn't driven within a couple days the battery is dead.
I'm curious if this my be a result; when you turn off the ignition the cluster says "Goodbye" and disappear you lock it and there's a blinking red light on the radio and the left side of the cluster.
But.... if you open the drivers door only, lets say to retrieve something the cluster will say "Welcome" disappear and repeat over and over. if you shut the door it continues to say it over and over again. you physically have to put the key in the ignition turn on then off for it to say " Goodbye" before it will turn off. Has this happen to anyone else? anyone have any insight on this issue?.
i just saw a post on the blue tooth module so i will check that also.
psusmacko15
Nov 2, 2020 12:53 PM
