Cannot Change Temp with Climate Control AC running wide open!
09 RDX Tech. I am not able to raise the temperature setting while ac is running. Continues to blow ice cold when set up to 85 degrees!
Appreciate any guidance.
May want to check your blend door. Your driver's side is near the gas pedal. You should see/hear it working as you adjust the temp from full hot to full cold. If it's not working, check the connection first - I had one that was just loose and unplugging and re-plugging it back in worked for me. Been 2+ years now. But if that doesn't work you may have to replace the actuator.
Thanks for your suggestion. The blend actuator is moving smoothly.
Does the a/c not turn off when you press the a/c button? Assuming it still disengages, does the air temp change when you have it just on the fan (you should at least be able to tell whether it's actual heat vs just whatever warm temp it may be outside). If there is some issue with your heater core or thermostat then you might not be able to get *hot* air, but it shouldn't be any cooler than outside temp if the a/c is not running.
Great Point Tom
Got it fixed! Heater Valve and cable was stuck!
Thanks everyone for sharing your knowledge!
Pilot
