Weak AC?
I thought my A/C was a little weak as well but not enough to consider it a problem. I just assumed it was because of the large space and large windshield that it had to work with. When I got the vehicle back after my first oil change the climate control temperature had been set to "lo" and the A/C came on blasting. I thought that was kind of strange. I set it back to "Auto" and ever since then it has been much better. Don't know if a). they changed something b) it just needed to be exercised c) I had something set wrong d) it's all in my head. But no harm in blasting it for a few minutes to see if that changes anything.
Originally Posted by Fishbulb
Hmmm.. I don't use the climate control, I just have it set to "LO", with the AC on, and adjust my comfort level with the fan speed. I don't suppose that the climate control actually can get the air colder.... doubtful, but I'll try it.
cold here
My a/c is cold enough for people to complain its too cold-even when its 98 outside.However I do notice if in "recurculate" mode it is colder than with fresh air coming in-especially when its real hot outside. Contrary to Acura's recommendation, I leave it in recurculate most of the time.
Originally Posted by turboted
95 degrees in the San Fernando Valley, CA, today my RDX is very cold.
If the vehicle has been sitting in the sun it takes a little while to get good cooling, but once the vehicle is moving, I'm surprised at how well it works.
Mine dumps gallons of condensate on the ground after parking....
Originally Posted by F.Rizzo
Correction: 103 in Woodland Hills today and it works great. !!
