Vit Tuned Thread
Old Jul 22, 2015 | 11:14 PM
  #201
KenB350z's Avatar
Originally Posted by csargemg
Well, these are the results that I got at this dyno, and it seems like it's a pretty good shop. He told me that he'd had a few stock ones on the dyno, and they all hit at about 170-175 awhp.
This was my second visit to the shop, and I was all set up to hire him to fine tune me at WOT. He only charged me for 3 pulls and said that he couldn't do better than the VIT tune, that everything looked fine. I'll be happy to post up datalogs from the pulls and the information he got.
Give about 28% power loss in the drivetrain based on this information, that means that I'm about 290 at the crank? compared to 240 stock? I'm personally not disappointed in that at all.
WTF, this has no merit at all. He is running FWD, so there is no drivetrain loss what so every. Unless of course he got it fixed to run AWD, but from the most recent post, he is only running FWD...
Old Jul 22, 2015 | 11:20 PM
  #202
KenB350z's Avatar
Originally Posted by rdxchris710
Brake boosting and launching at 1700. It's hard to tell with vits revisions but the 3 I've gotten since I've been to the track have been killer. I've had a couple nice exhaust pops banging 1st to second and can bark 2nd easily if my foots in it a little to much. I know I am in the low 14's now, the tune has way more balls. Picking up my new axel this week and can have my awd back. I didn't launch to high in fwd otherwise it just smoked the tires. Here's the only in car video I had from the track.
I doubt you would have smoked the tires, if your track is like any others; then it would have some sticky compound on there and with your current HP numbers there is no way it would have broke loose. This is me when I ran a 14.8 while running just FWD, tires didn't even brake loose.
Old Jul 23, 2015 | 05:26 AM
  #203
hypnotini's Avatar
Acura RDX vs BMW 335i - YouTube
in fwd mode only mine break loose it also depends on your tires....you have much wider ones.
Old Jul 23, 2015 | 09:17 AM
  #204
KenB350z's Avatar
In the video I was running a 235/40r19. I didn't get the 285 until after this video.
Old Jul 23, 2015 | 11:43 AM
  #205
KenB350z's Avatar
Don't get me wrong the tires will definitely break loose on the street which I experienced this with all my tire sizes the 275 the 285 the 235 and the factory 235. On the track it's a different story. Unless you just got some really bad worn out tires then it could be achieved.
Old Jul 23, 2015 | 12:04 PM
  #206
Tomtwtwtw's Avatar
Also, depending on your local strip, how the track is prepped. I used to go on the "run what you brung" drag days, and the prep really varied from week to week. I do love the smell of fresh VHT.
Old Jul 25, 2015 | 05:14 AM
  #207
hypnotini's Avatar
true the street its super easy
Old Jul 28, 2015 | 03:44 PM
  #208
csargemg's Avatar
Huh? I'm talking about on mine. These results were on an all wheel dyno.
Also, there is drivetrain loss for two wheelers, I'm pretty sure - no car gets the same whp as they do bhp, it's just that the difference is less pronounced.
Old Jul 31, 2015 | 08:26 AM
  #209
rdxchris710's Avatar
RDX faN BoY
Starting to get a tranny issue. Going to do a flush. I'm guessing it's a selonoid but in S sometimes when its super hot it is getting stuck in second. I just won't shift even going to D. I can monitor trans temp in torque so its somthing i will have to keep a eye on. Waiting for revision 3.0 to show up. I ordered a new axel when I get to put it in who knows . should take 20mins to do. My front tires are just about slicks now. Driving in the rain is tough .. Spins even in higher gears at low rpms romping on it.
Old Jul 31, 2015 | 08:49 AM
  #210
KenB350z's Avatar
How is your daily driving if it is anything like the driving in your videos , you are going to have issues. Take it easy on her.
Old Aug 2, 2015 | 08:32 PM
  #211
gearhead98's Avatar
7th Gear
Not to stir the pot, but these are around the numbers I layed down with no mods only the flashpro and a really quick tune.
6 speed auto would be amazing.
So, my vit tune's just finished up, and it didn't even need WOT tuning at the dyno I went to.
Results? 207whp, 222 wtq. Not bad at all, I think, considering my mod set - I'm pretty much running nothing other than ETS intercooler, RV6 downpipe, flashpro, and 800cc injectors. Max duty only 52% on the latter, so if I went further I'd have a lot of headroom there.
For now I'm just going to sit on things, and wait until all the kinks are worked out of Wrench's 3.5" MAF housing and tune. Since I'm at 4.85v on my MAF sensor, I'd max it out if I did a catback at this point.
I think that must be where I'm losing boost up top: the turbo can't push any harder against the exhaust restriction. But to do exhaust I'd need more room on the MAF sensor...and...
So! Keep us updated and let us know when you've got a tuned that's scaled for your 3.5" Wrench!
Old Aug 5, 2015 | 05:16 PM
  #212
csargemg's Avatar
Not stirring the pot at all! Got logs and cals? I'd love to see.
Particuarly if you datalogged your dyno pull, I can maybe see what's going on in mine, if I'm pushing low.
Old Aug 20, 2015 | 04:22 PM
  #213
gearhead98's Avatar
7th Gear
So like I said this was a quick and ugly tune to see what the car would make if we played with boost and timing a little. To be clear, car never left the dyno on this tune, we flashed back to a map i use for fuel economy. Just can't figure out how to upload it.
Old Aug 20, 2015 | 08:15 PM
  #214
TheWrench116's Avatar
FLETCH
hey mods can yall add the .fpcal to the allowed list of uploads?
Old Aug 20, 2015 | 08:21 PM
  #215
FLETCH
on another subject...
how many are done with there VIT TUNE? i know of one who is finished. i my self am getting closer i'm on revision 4.2 at the moment. with the traction control off it yanks the steering wheel all over the place when you punch it now. its nuts boost is only set to 13-14 ish psi. so hard not to go in and fiddle with it and crank it up!!!
Old Aug 20, 2015 | 10:19 PM
  #216
csargemg's Avatar
I'm done, but I just paid for a retune in order to get a starting map for intake with 3.5" maf housing and 3" double-muffler catback.
Old Aug 20, 2015 | 11:21 PM
  #217
KenB350z's Avatar
On my first 1200cc tune body still in the air. I will have him tune this puppy when we're done putting things back together. I want to see this against the RDX.
Old Aug 20, 2015 | 11:32 PM
  #218
KenB350z's Avatar
Putting in overtime!
Old Aug 20, 2015 | 11:55 PM
  #219
KenB350z's Avatar
Might go K-series
Old Aug 23, 2015 | 01:34 PM
  #220
hypnotini's Avatar
my rdx has been done for a long time till i buy more parts. my 8th gen civic si was also tuned by vit but car is sold.
Old Aug 30, 2015 | 06:00 PM
  #221
FLETCH
cool good to know. its a long road for me yet i think but the car keeps getting better every time with every revision.
Old Sep 6, 2015 | 12:22 AM
  #222
xJdmTL86x's Avatar
5th Gear
Nice build guys the next thung I'm buying is flash pro and a vit tune kinda of hard when I don't have a job lol thanks for the motivation
Old Sep 14, 2015 | 08:44 PM
  #223
RDX faN BoY
Best et. 4050lbs. #37 revision, still in fwd. Did the axel. Had awd for a hour started beating on it and set a light.. Sensor is dirty so 1 more cleaning and should be good. I dropped tire pressure to 20psi in the front .heat soaked grabbed my by the balls as I could not resist hot lapping. Ran 15.0's all day like constient as hell.. Iats at 135-140.. I've worked but did t last long. Staging lanes killed me, the cooler weather I'll go back before it closes and shouldnt be a issue.my best RT of the night was a .080 I was supped. That was all I could really work on besides launching when it was heat soaking.
Old Jan 3, 2017 | 01:26 AM
  #224
allmotorap2's Avatar
Really looking into taking the next step with my rdx and buying flashpro and injectors. Wont take much to get me into the 13's considering I ran a 9.1 @ 75mph in the 1/8th with only a reflash and rv6 catless downpipe. Some good information in here guys, thanks for sharing!
Old Aug 23, 2017 | 11:15 PM
  #225
Billsrdx's Avatar
Vit tuned
I just bought my 12 Rdx a week ago and purchased flashpro and a vit tune , looking at getting a rv6 downpipe and injectors before he tunes it. Excited to see how it runs even with just flashpro. Best part about the rdx , it doesn't appear to be a car that would be fast so will surprise a lot of people .
Old Aug 24, 2017 | 02:50 PM
  #226
vpn2001's Avatar
I had a bad experience with Vittuned.
I ordered the Flashpro + Ultimate Tune on July 28, 2017 in preparation for all my mods.
On August 14, I inquired about the status of my order.
I received an email stating that the Flashpro was a special order from Hondata and that he will order it for me this week.
When I questioned why he didn't order it when I placed my order, I received a refund email with no explanation.
I hope your transaction go smoother than mine.
Old Jan 22, 2018 | 10:06 PM
  #227
Billsrdx's Avatar
Vit is a busy guy and I know that so when I ordered mine I simply patiently waited . Vit doesn't stock the rdx flashpro so he has to order them from hondata and from there he ships to you . Believe me ive had to have allot patience with my build so far. Took 3 months after ordering my parts till I got them installed and now Im having transmission issues which Im hoping to have fixed by wed this week. Vit has already started tuning mine but I had to wait 2 weeks almost from time me and josh fletcher installed everything till vit got my idle well enough to drive the car. Well my trans fluid was older and now from setting it caused sticky trans press switches so my 2nd-3rd shift , 3rd - 4th and 4th to 5th is horrible now . So once I get the switches changed im hoping soon to be able go Wide open throttle with my rdx. Only hit 9 .5 psi part throttle so far.
Old Jul 30, 2018 | 02:32 PM
  #228
CSmoney28's Avatar
CSmoney28
Good afternoon,
I heard he’s not tuning any new cars anymore, is this true?
Old Jul 31, 2018 | 07:59 AM
  #229
Billsrdx's Avatar
Originally Posted by CSmoney28
Good afternoon,
He is still tuning cars but no longer with Hondata or ktuner. Only thing he uses now is Motec which is a high end computer and very expensive. Around 5000.00
Old Jul 31, 2018 | 05:21 PM
  #230
CSmoney28's Avatar
CSmoney28
Good evening,
Thanks, for the great response. That’s a ridiculous amount of money for suvs that have over a hundred thousand miles on them. I’ll just stick with the hondata. Thanks for the info. I appreciate it.
Old Aug 5, 2018 | 11:57 AM
  #231
oseanavinlano's Avatar
Based on my research, Vit was arguably the best e-tuner for the 1G RDX.
I’m looking to get FlashPro for my RDX, and I don’t have any local tuners, so e-tune sounds like the best way for me to get the most out of the software. Now with Vit leaving the market, are there some other reputable e-tuners out there we can turn to?
Old Aug 18, 2018 | 01:14 AM
  #232
CSmoney28's Avatar
CSmoney28
Good evening,
I was told to try out these guys...
E-Mail Tuning Service / E-Tuning Honda Acura
Old Nov 5, 2018 | 02:59 PM
  #233
RRK0818's Avatar
Anyone know how to reach Vit?
I am trying to get my tune updated (never finished it) I tried to submit my data log through Vits site as usual,however, it has disappeared and has a new skin. I tried support@vittuned.com, and Facebook without a response. I'm sure he is busy, just trying to get my file inline to be updated.
Old Nov 7, 2018 | 04:18 PM
  #234
CSmoney28's Avatar
CSmoney28
Not sure, I know people have emailed and not gotten responses in the past.
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
Jul 16, 2017 07:33 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
